help . check engine light
Old Oct 20, 2008 | 09:15 AM
S2KCHRIS305's Avatar
Thumbs down help . check engine light
i have a 2003 honda s2000 with 52k miles on it . today my check engine light came on on the way to school . on the way home i passed by the autozone and obd scan my car and i got 2 codes . i got p0172 and p0170 running to rich and fuel trim malfunction .i check the the fluids and everything looked fine . the engine looked fine and the car runs perfect . can it be a sensor ? well i reset the ecu by pulling the back up fuse out and the light came off and the car runs fine still but it seems like it has less acceleration then before . what caused the check engine light to come on ?can it be a sensor ? or did the ecu just had to be resetted ? i recently did the clutch my self and a allignment done at the dealer . thanks .
Old Oct 20, 2008 | 09:31 AM
bcs's Avatar
bcs
O2 sensor? Maybe the MAP Sensor.
Do you have a test pipe?
Old Oct 20, 2008 | 09:33 AM
no i have no test pipe . my car is completely stock just has an aftermarket clutch disc and lightened flywheel . yea i was thinking 02 sensor or map sensor also. but wouldnt the light come back on after the reset if they were really damaged?
Old Oct 20, 2008 | 09:35 AM
bcs's Avatar
bcs
Not necessarily...
Sometimes it takes a little bit of driving for it to come back on. If you reset the ECU and then just turn the car on, it doesn't mean that the CEL will come back. Go drive around for 30 minutes and see if it comes back.
Old Oct 20, 2008 | 09:58 AM
yea ive been driving and so far it hasnt came back on . but i got a feeling it is gona come back . cause why would the light come on in the first place if nothing was wrong
Old Oct 20, 2008 | 11:07 AM
dparm's Avatar
OBD2 systems are finnicky, they tend to throw codes a bit too often.
If the light doesn't come back on, I wouldn't worry about it.
Old Oct 20, 2008 | 12:10 PM
fatjoe10's Avatar
Before the CEL comes on again, all related monitors need to have a status of "READY". For example, if the O2 sensor is malfunctioning, it will not throw a code for it until the ECU checks on its status and an actual check afterwards.
a.sunnucks
Jan 18, 2014 05:58 AM
irev9k
Aug 15, 2010 07:40 PM
f20cpower3
Apr 15, 2010 01:14 PM
Bibbs
Sep 22, 2005 11:16 PM
