HELP! Coolant in cylinders
Old Apr 1, 2005 | 08:17 AM
s2k-mtl's Avatar
Thumbs up HELP! Coolant in cylinders
Hi,
This is my first post. I hope somebody can help.
I just finished replacing my head gasket. When I turn over the engine it would start and eventually it jammed. I removed the spark plugs and turn it over again. What I saw was a coolant fountain. After I checked it the intake manifold and it was also full of coolant. Where can all this coolant be coming from? I used a new head gasket and a new intake manifold gasket and torqued all the nuts and bolts to factory spec.
Somebody please tell me I don't have to pull the head off again. Could it be the intake manifold gasket?
All suggestion will be appreciated
Carl
2000 S2K
Vortech Supercharger
AEM EMS
Remus Exhaust
Bilstein Coil Over Suspension
18" SSR Competion w/ P-Zero Rosso Corsa
Old Apr 1, 2005 | 08:29 AM
stitos2k's Avatar
Ehh, had this happen on a different car.... It was the headgasket... I'm wondering if the gasket got pinched or bunched up somewhere when you put it on. Or if it somehow got torn or didn't seat correctly... That's about the only way I could think of coolant getting into the cylinders.
Just couldn't tell ya man, I'm not an expert on s2000's by any means. Hopefully someone else will chime in with an idea.
Old Apr 1, 2005 | 09:57 AM
3ngin33r1's Avatar
Keep trying...
(if this really is a problem and not a 4/1 thing, it's your head gasket).
Old Apr 1, 2005 | 10:42 AM
Ztec's Avatar
If this isn't another april fools joke you could have very easily switched the two hoses that connect on the side of the intake manifold coming from the idle control valve - they look very similar - One is Vacumm and that one sits directly behind the throttle body and it is "L" shaped and brass looking and points straight down and the other is coolant and if you reversed them it WILL dump coolant directly into your intake mani! Both These hoses sit directly behind your throttle body!
DO NOT crank your engine anymore with the spark plugs in until you find out the cause or you could destroy your engine with a hydrolock - If you have coolant in your cylinders you need to get it out of there by whatever means you can - use a tube and suck it out if you have too - try cranking the engine w/o plugs and cover your painted surfaces because it could come out like a fountain then I would change your oil!
Do a search on Hydrolock for more information!!!!!!!!!!!
Old Apr 1, 2005 | 11:14 AM
3ngin33r1's Avatar
forgot about those two. nice catch.
Old Apr 4, 2005 | 10:53 AM
s2k-mtl's Avatar
Ztec, you were right. The coolant and vacuum lines were switched. I'm lucky honda uses a metal head gasket on this motor
Old Apr 4, 2005 | 05:10 PM
Ztec's Avatar
I would say you were lucky as well, I assume you did no damage but I would suggest at least a couple of oil changes in the very near future
Old Apr 4, 2005 | 05:20 PM
Ooalloems2koO's Avatar
while back i installed the aem intake on my friend's GS-R and i switched the coolant hose and intake hose so the coolant got into engine
it vent the valves and pistons.... u need to change those
possibly worse..
Old Apr 4, 2005 | 07:39 PM
s2k-mtl's Avatar
Post
it bent the valves and pistons.... u need to change those
possibly worse..
Car runs fine. I put some gas line antifreeze in the cylinder and turned the engine over, without the spark plugs, to get the remaining coolant out and just changed the oil and the spark plugs. The engine never ran with the coolant in it, only turned over with the starter.
Stine
43
Jul 25, 2016 09:47 AM
AusS2000
Aug 31, 2008 06:00 PM
NFRS2kSi
Jan 14, 2006 11:13 PM
Asura
Aug 19, 2005 07:19 PM
Gernby
May 29, 2002 12:35 PM
