help engine code
Old Oct 7, 2011 | 08:09 PM
oneandonlyjuarez's Avatar
Default help engine code
I recently installed kn fipk intake, and check engine came on. i took it to advance they said indirect flow of air, all the lines are correct as of what i've looked up, another thing the car will not pass 6000 rpms. the only code that popped up was the flow air ..thank you in advance
Old Oct 7, 2011 | 08:27 PM
D-Jetronic's Avatar
what was the code number
Old Oct 8, 2011 | 05:39 PM
Utah S2K's Avatar
Every time I have seen someone throw a code for an intake it has been only 1 thing. There is a small inline check valve on one of the vacuum lines. Most likely it was reversed during the install. It's VERY easy to do!
Utah
Old Oct 9, 2011 | 09:08 AM
s2klariat's Avatar
Run a search for PO410 Check engine light. You will find your answers there
cvedral
Mar 26, 2013 06:36 AM
Fatcow21
Sep 12, 2008 07:52 AM
flopez82
Sep 7, 2008 08:03 PM
phillys2k
Jun 5, 2006 10:32 AM
Goldtrom
Dec 21, 2004 07:18 AM
