Help with EPS!
Old Jun 7, 2004 | 06:29 PM
slavka's Avatar
Default Help with EPS!
My car was in a small accident and the power steering won't work.
What is it that I need to check first myself before taking to mechanic or something?
All components are there, Are there any common failures with this system?
Advise greatly appreciated. Thanks.
Old Jun 7, 2004 | 07:36 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
If the EPS light is on, then you need to start with pulling the trouble codes.
Old Jun 7, 2004 | 11:00 PM
slavka's Avatar
I assume I need to buy some kind of book to pull those trouble codes, right? Or is there some other ways?
Old Jun 9, 2004 | 06:43 PM
Blkturbos2k's Avatar
You need to go to Honda or a shop with a OBD2 scan tool. Have you drove your car? If not drive it for about a hour at highway speed and it may reset
Old Jun 9, 2004 | 07:04 PM
modifry's Avatar
Honorary Member
You might try pulling fuse 33 for a minute, a 70 amp fuse in the under-hood fuse box. I've not done this but it's the main feed to the power steering control and might reset it. There doesn't appear to be any other 'constant" power to the unit.
Have you driven the car? In the past I've pissed off my EPS unit by removing the tach wire with the car running and the EPS light came on and there was no power steering. But it reset as soon as I drove the car at low speed (like 10mph).
BA4toAP1
Jun 10, 2021 05:50 PM
speedzx
Feb 28, 2017 11:27 AM
667
Dec 18, 2006 08:23 AM
hass2k
Nov 28, 2005 03:43 AM
marcucci
Apr 24, 2002 04:25 PM
