Help! Getting a flooded engine.
Old Jun 20, 2018 | 04:02 PM
tx_s2k's Avatar
Default Help! Getting a flooded engine.
I just replaced my injectors and fuel pump in my 00 ap1. Previous symptoms rough idle and dying at the light. Car is bone stock. I cleaned off my plugs then put them back in. Started car and it runs good at idle but as soon as I give it gas it chokes and misses. Pulled the plugs out and number 2 and 3 are both flooded as they smells before changing injectors. What could I have missed? I'm changing the plugs tomorrow. What else should I consider?
Old Jun 21, 2018 | 07:40 AM
Car Analogy's Avatar
How do you know new injectors are good? Maybe move them around, see if flooding issue follows the injectors.
Old Jun 21, 2018 | 02:49 PM
tx_s2k's Avatar
Swapped them nothing changed. Only code I'm getting is p0131 and I've already changed the 02 sensor. Attached is what I'm getting as readings if that helps .
what else can I consider? I give it throttle and it chokes out at first then slowly builds rpms. Tried to move it but it has very little power. I pull the vaccum hose on top of the fpr and the idle picks up tremendously.
Old Jun 22, 2018 | 03:45 AM
Ok, so you can rule out injectors. Good. Moving on. Its either too much fuel or not enough spark.
Your experiment with the fpr sounds like a good place to start. Whats your fuel pressure?
Old Jun 28, 2018 | 02:28 PM
jyeung528's Avatar
interesting.
Old Jun 28, 2018 | 04:37 PM
tx_s2k's Avatar
I haven't been able to test fuel pressure. I can't seem to find the right fittings. Put a test tps and map sensor off a working s2k and still runs like crap. I wonder if the reman injectors are causing any of it? I have a new fpr on the way and will see if that changes anything. After this I'm going to blow it up!
Simann
Jul 10, 2010 01:01 PM
silvery2ks2k
May 18, 2009 07:13 PM
DRE.
Oct 16, 2007 05:50 AM
NerveAgent
Jun 12, 2007 11:15 PM
preppyS2000
May 3, 2006 01:28 PM
