HELP license plate threads fell in
Old Sep 19, 2024 | 03:22 PM
DLys2k's Avatar
Default HELP license plate threads fell in
I was trying to put some plate plugs into the front bumper when the entire piece that holds the bolt fell into the bumper. Is there an easy way to get it out or will I have to take off the whole bumper?
Old Sep 19, 2024 | 03:32 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
-Pull the bumper
-reinstall the two plates
​​​​​​-cover both plates with a few layers of heavy duty duct tape, they will never fall again.
Old Jul 4, 2025 | 09:05 AM
Halo's Avatar
Resurrecting this because I gave it a shot w/o removing the bumper cover.
The female thread piece had fallen into the bumper. I could see it. With a magnet, I pulled it up to to line up with the holes. Threaded a M6 bolt into one side, removed the magnet, threaded another M6 bolt into the other side. Then I tried to gently pull it into place. This got it seated in the steel frame member behind the bumper cover. Unfortunately, it seems like it would require too much force to pull it any further. If I could keep tightening the bolts against metal that would pull them in all the way but unfortunately, the plastic bumper cover is the leverage point so that's not possible. I really don't want to take the bumper cover off so will see about extending the pins on the plastic cap that covers the holes to see if that works.
The good news is that when this thing falls in there, it can't really go anywhere.
Old Jul 4, 2025 | 09:32 AM
Chuck S's Avatar
Would love to see photos. My detail guy pulled my front license bracket and, of course, the bolts (or whatever they are) fell inside. I've been using a nylon trim thingie to retain the bracket. Goes in the hole and then expands inside the cavity. Been working for a couple of years but ain't right.
-- Chuck
SupraTwinTurbo
Jun 25, 2021 10:10 AM
markpenske
13
Aug 12, 2014 07:38 AM
bluerennfahrer
Oct 7, 2010 01:17 PM
Blazer80
Apr 11, 2009 07:06 PM
chuhsi
Jul 8, 2007 01:30 PM
