Help, need to get my daily going....
Old Feb 9, 2014 | 03:33 PM
omarv234's Avatar
Default Help, need to get my daily going....
hey guys, so my 2007 s doesnt seem to want to start. this is the second time this has happened. I go to start my car normally it makes all the normal beeps, when i go to crank the engine all of my electricity cuts. Absolutely nothing. later that day thinking my battery was dead, i used some jumper cables to get it going. i drove it for 3 days with nothing wrong. Last night i go to turn on my car and again same thing......so i went to get my battery checked and it was good, i later find out that my horn works. none of the electricals work but the horn. i tried using jumper cables again, and nothing.
if anyone can help, id really appreciate it this is my daily and i need to get it going. Thanks!
Old Feb 9, 2014 | 04:47 PM
MR.T's Avatar
first step would be to check terminal connections. pull them off and sand any rust or acid build up, then reinstall.
Old Feb 9, 2014 | 05:41 PM
omarv234's Avatar
well the car only 37000 miles, idk if it could be that, but it wont hurt to tryyy ill do it and see what happens thanks!
Old Feb 9, 2014 | 06:05 PM
_brandon's Avatar
Try replacing the battery or getting it tested? Batteries do go out and it is around 6 years old most likely with the OEM battery lol
Old Feb 9, 2014 | 06:14 PM
kwin5946's Avatar
Do you have a multimeter? A quick way to check your your alternator is to check the voltage of the batter while the car is on and off. When the car is on the voltage should ideally hover around 14 V while off around 12 V.
Old Feb 9, 2014 | 06:20 PM
Murphg05's Avatar
^ +1
I'm on my 4th battery on my '01. Replace the batt and inpsect/clean terminals and cables.
Old Feb 9, 2014 | 10:46 PM
omarv234's Avatar
thanks for the input guys, turns out it was a blown fuse. kinda weird how one fuse controls everything. But thanks again!
JosephS2K
Apr 21, 2011 09:27 PM
gilwood
Mar 23, 2010 12:20 PM
SorakS2K
Feb 7, 2010 08:02 AM
howardtan
May 31, 2008 05:48 PM
RYBA34
Jan 16, 2007 06:10 PM
