help needed p0411
so i need to pass emmisions and i bought a used ap1(2003) that had a ghetto intake system on it. so i bought the stock intake system off a member and hooked up every thing including the tube from the pump......welll the pump work and kicks on at cold starts but i realized the two hard vaccum lines that come and split by the injectors are just routed together with a small vaccum(u shaped) line. well i have the old vaccum tank and seloniod off my gsr and wondered if i could use that to run the vaccume lines through(the plug plugs in to the selonoid).....i have a print out of the stock one and it looks simaler? i dont know what to do i just need to pass emmisions soon! it runs fine. it just has a code and you know how they are about that. any ideas? to get around
or do thins the right way?
thanks guys
or do thins the right way?thanks guys
If you are getting the P0411 code take a look at this thread:
https://www.s2ki.com/forums/index.php?showt...0&#entry6795026
