Help! New oem serpentine belt doesn't line up
Old Jan 30, 2017 | 02:32 PM
Boston pride in Florida's Avatar
Default Help! New oem serpentine belt doesn't line up
So I bought a new oem belt from Honda, Part# 38920-PCX-024. I've notice that one of the guide pulleys are off alittle making the belt start to come off on the tensioner pulley. Idk if it was like this before but I replaced the old one due to it being cracked and starting to squeal. Anybody know what's going on? I didn't change anything other than the belt.
Old Jan 30, 2017 | 02:39 PM
Old Jan 30, 2017 | 02:41 PM
Chuck S's Avatar
Worn bearings in the pulleys will look like this. Should be something in the maintenance section but it may be a bit of a search.
-- Chuck
Old Jan 30, 2017 | 02:49 PM
-- Chuck
which bearing sir? Would like to make my ap1 reliable and be up to date with maintenance, just bought my first s2000 last week
Old Jan 30, 2017 | 05:02 PM
windhund116's Avatar
You'll need to remove the belt and inspect each idler pulley or accessory driven by the belt. What position was the wear indicator arrow, after you replaced the belt? I suppose it is possible that the wrong belt was packaged in the one you bought.
Anyhow, here's a good YT by Eric the Car Guy, on belts.
How to replace:
Old Jan 31, 2017 | 08:30 AM
Spartarus's Avatar
The idler you show in your photo has a spacer from the factory. I will bet yours is missing or installed on the wrong side, from the visible misalignment...
The idler is visibly recessed relative to the crankshaft pulley and auto tensioner. Also, that spacer keeps the pulley aligned, because the bolt is narrower than the hole in the bearing. It looks as if yours may have slipped out of alignment, implying that the spacer in question might be missing altogether.
Labeled "5" in this diagram
Attached Thumbnails Help! New oem serpentine belt doesn't line up-capture.jpg
Old Jan 31, 2017 | 09:10 AM
Car Analogy's Avatar
Make sure the belt isn't off by one grove at the crank.
Also, when you remove that bolt to look for spacer #5, be careful about reverse threaded bolts. Can't recall but I believe its the tensioner pully that uses a reverse thread. The reverse threaded bolt has arrows on it showing direction to loosen. The one you are removing to look for spacer is idler, so I think that one has normal threads. But check for those arrows to be certain...
Old Feb 2, 2017 | 03:01 PM
I found my problem guys.. turns out my crank pulley is starting to pull away from the block. Is it normal for a crank pulley to do that due to age? Car has 138k and I just got it last week.
Old Feb 2, 2017 | 03:22 PM
Hfreak's Avatar
That is certainly not normal, make sure the pulley bolt is tight but if it is then you may have other issue unfortunately.
Thomas Guide
Jan 28, 2019 01:30 PM
bhahlbeck
Oct 3, 2017 05:06 AM
Feb 8, 2017 05:56 AM
garyg4761
Apr 18, 2016 02:21 AM
Injection Imports
UK & Ireland Traders Forum
Mar 14, 2016 11:27 AM
