Help Over rev the S
Old Sep 23, 2010 | 08:36 PM
Dumas2k's Avatar
Default Help Over rev the S
I shifted from 2nd instead of 4th changed it back into place. but as i was driving the clutch was super shaky...... can someone tell me what happened? but about 15 mins later it went away..?
Old Sep 24, 2010 | 08:21 AM
idea-catalyst's Avatar
Can you be a bit more specific about what happened? You can only shift "from" the gear that you are in, so maybe you mean that you downshifted from 5th into 2nd instead of your intended 4th? If so you likely over-revved (search the forum for overrev discussions). How serious was the overrev? How long? Any other symptoms? When you say the clutch was "super shaky" do you mean that it vibrated like it was out of balance, or something else about how it engaged or disengaged?
I don't know that I'll have all (or any) of the answers, but more information would be helpful.
Old Sep 24, 2010 | 09:42 AM
Dumas2k's Avatar
i was in 3rd gear and redline and shifted to 2nd instead of 4th. i was going 90mph then. It wasnt in for too long and was able to throw it back in neutral.
It might have kick back like 4 times at the most. I dont know if im over exaggerating but the clutch felt shaky as i hovered my feet on it and press down, Right before it engaged. but then it went away.
Old Sep 24, 2010 | 10:06 AM
Reckon's Avatar
At a minimum, you need to get a compression test and leak down test done to see if there is an issue. Do a search on this subforum for overrev and you will see what has been recommended be done after a possible/definite overrev. If you were at redline in 3rd gear and shifted to 2nd, my guess is that it went well over any safe limits. Get it checked out asap.
Good luck!
yarou
Apr 21, 2006 07:17 AM
BerlinaBlackS2kguy
Sep 23, 2004 11:45 AM
wadswoaj
Sep 6, 2004 12:32 PM
shauniewalnuts
Jun 3, 2004 09:01 AM
SonTon2003
Nov 4, 2003 09:20 PM
