Help Please Banging Noise
Old Sep 10, 2007 | 12:25 PM
G375 DAN's Avatar
Default Help Please Banging Noise
After a lil spin last week I have replaced the passenger side rear alloy, hub, lower wishbone and suspension.
Now when putting it into gear or changing gear I hear a "thud" so I looked under the car and the drive shaft seems to be loose.
Does the drive shaft just sit in the rear diff? or is it held in some how? as the drive shaft legs seem very loose when it sits in the rear diff and has alot of play
Would be great if someone could help me out so I can finally get the car back on the road
Old Sep 10, 2007 | 01:25 PM
MikeyCB's Avatar
Though I don't have first-hand experience, some recent posts indicated an inordinately high amount of play in the S2000 driveshaft. Are you talking about rotation, or front to back play?
Old Sep 10, 2007 | 05:02 PM
dbzerk's Avatar
Is the noise coming from the diff?
Old Sep 10, 2007 | 11:52 PM
G375 DAN's Avatar
Yes It Sounds like it
The drive shaft can be turned around by hand an inch or so at the dif end
Old Sep 11, 2007 | 05:42 AM
tinkfist's Avatar
Drive shaft or half shaft? It sounds like you are describing the half shaft, so I'll assume that. Make sure all the bolts on the half shaft flange are tight against the diff output flange (60+ ft-lbs IIRC). Also, make sure that axle nut you replaced is down tight - 220 ft-lbs
Old Sep 12, 2007 | 12:16 PM
SpitfireS's Avatar
With drive shaft you mean the output shaft?
These ones?
If so, they "float".
They are held in place by a circlip and are not really supported by a bearing in the diff.
The splines fit in the side gear in the Torsen.
That circlip sits in the little groove in the middle of the splines.
G375 DAN Posted on Sep 10 2007, 10:25 PM
Rotational or up & down?
All of this was not there before the lil' spin?
If not, then it was probably caused by it, or by the install of the parts.
Old Sep 12, 2007 | 10:58 PM
G375 DAN's Avatar
i have ben given this informaion which sounds about right.
"the tripode joint if it is the inner end that's got the play. You've usually got three wheels with needle rollers in them & they can fall out"
does anyone have anymore information?
Old Sep 13, 2007 | 09:48 AM
SpitfireS's Avatar
IIRC you can get the tripods (spiders) seperatly.
I hope this helps you.
mk84
Oct 23, 2008 07:35 PM
G375 DAN
Sep 11, 2007 03:05 AM
zangiefisgod
Nov 8, 2005 07:10 PM
CIVICTOS2000
Jul 20, 2005 09:07 AM
allenheathdj
Nov 13, 2004 08:40 AM
