Help with pulleys!
Old Mar 23, 2015 | 03:34 PM
S2k_razy's Avatar
Default Help with pulleys!
The Lower right pulley that's next to the crank pulley, what is it called? How do I take it off?
What would happen if a ONLY a few drop leaked out (it's not leaking) I just unscrewd a wrong bolt and some liquid started to leak out so I tighten it back up. Just trying to take it off so I could drop the oil pan because it's in the way.
Old Mar 23, 2015 | 03:58 PM
zeroptzero's Avatar
The big pulley next to the crank pulley is the water pump, it is held on by 3 10mm bolts. Saying that, you should not need to touch the water pump pulley for the oil pan removal, I can't see how removing it will help with the oil pan removal. You can remove the oil pan entirely from below the engine without touching any pullies.
Old Mar 23, 2015 | 05:52 PM
Slowcrash_101's Avatar
You sure you're not talking about the AC compressor right?
Old Mar 23, 2015 | 06:11 PM
zeroptzero's Avatar
^ that would be two pullies over from the crank, but yeah he may have opened up a bolt on the refrigerant system, which would seep out.
To remove the oil pan, simply remove the two lower bolts under the A/C bracket, the A/C compressor is not moved or disassembled in any manner. I believe they are 12mm bolts, and they are accessed from underneath the engine, you don't remove anything from above.
Old Mar 23, 2015 | 06:25 PM
S2k_razy's Avatar
Yes the ac compressor! Is it bad that it leaked out a bit? & I do need to remove it to get to my oil pan because it's blocking two bolts I can't get to die to small space.
Old Mar 23, 2015 | 06:50 PM
zeroptzero's Avatar
All you need to remove the two lower a/c bracket bolts is a ratcheting box end wrench with a flexible head, once you get the two lower bolts out of the a/c bracket it will release the oil pan. You don't touch the upper two bolts ( 4 bolts in total on the a/c bracket), all done from underneath the engine.
Old Mar 24, 2015 | 02:42 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
All you need to remove are the two lower 14mm head bolts.
The little triangle bracket with the 3 12mm bolts will stay with the oilpan.
bimmerpowa
Oct 12, 2017 02:12 PM
S2k_razy
Mar 4, 2015 03:29 AM
mikecl713
Jun 7, 2004 04:41 AM
Rspec99
Jan 28, 2002 05:37 PM
