Help with TPS adjusting
Old Jul 25, 2009 | 06:07 AM
s2kvsall's Avatar
Thank You
Old Jul 25, 2009 | 12:09 PM
jefferyg32's Avatar
Use an ohm meter. Also cut a TPS/MAP plug off any HONDA harness and now you have a plug to plug into the sensor and use the extra wires to get your reading. I believe the setting for the S2000 TB is .687 ohms closed. You will never be able to set it using voltage without power being sent to the TPS. Ive always set them by ohms out of the car and had no issues. Hope this helps. If you need to i can get you the exact ohm reading if you need me to but i think its .687 off the top of my head.
Old Jul 28, 2009 | 03:59 PM
s2kvsall's Avatar
SO i can just go to any junk yard and find a honda throttle body and cut the tps/map sensor
Old Jul 29, 2009 | 11:14 AM
S2Kart's Avatar
Old Jul 30, 2009 | 06:19 AM
s2kvsall's Avatar
Thank you S2kart really do appreciate it
user 192245235243
Feb 26, 2011 04:42 AM
manny-s2000
Dec 9, 2010 04:00 AM
rocsix
Mar 20, 2010 12:26 PM
Pastor
May 30, 2009 11:12 AM
s2k Desi
Jun 12, 2002 11:25 AM
