HELP! what is this noise?
Old Apr 22, 2016 | 01:26 PM
AndresCR's Avatar
Default HELP! what is this noise?
Hi, i am hearing this noise days ago, i took the car to the shop to change all fluids thinking it was gonna be solve but no.. the noise still there, what do you think it is?
The noise is coming from the rear part by the differential I guess, it only sounds when i take out my foot from the gas pedal..
http://vocaroo.com/i/s1aNraAhIZUM
Thanks!!
Old Apr 23, 2016 | 06:00 AM
Slowcrash_101's Avatar
Wheel bearings.
http://www.ebay.com/itm/Rear-Wheel-H...tUHpvv&vxp=mtr
You can use these, or go OEM hubs and bearings but I've used this with decent success. Plenty of DIY's around.
Old Apr 24, 2016 | 09:17 AM
Reasonable Doubt's Avatar
If you're not sure which wheel it is lift the car and punch the wheel on its side and one should rattle more than the other. That's the bad one.
Old Apr 24, 2016 | 01:01 PM
To me I work the whole axle. I don't bother just replacing one shock, or one brake pad, or one tire, likewise I do both wheel bearings.
Old Apr 25, 2016 | 05:14 PM
AndresCR's Avatar
For which reason it only sounds when I'm desacelering??
Old Apr 25, 2016 | 09:05 PM
Soviet's Avatar
Does it only happen during a certain RPM?
Old Apr 26, 2016 | 02:53 AM
AndresCR's Avatar
Yes it usually does between 20m/p 40m/p
Old Apr 26, 2016 | 04:54 PM
Soviet's Avatar
Originally Posted by Soviet' timestamp='1461647106' post='23948393
[quote name='AndresCR' timestamp='1461633279' post='23948260']
[/quote]
I was asking about RPM not MPH. What I'm trying to get at is whether it is wheel speed dependent or engine speed dependent. Generally wheel bearings get noisier wheel speed. From your sound clip I think I hear at least clutch buzz, which is typically engine speed dependent (decelerating from 4k to 3k RPM).
Does the noise happen with the clutch in/out?
Old May 1, 2016 | 04:26 PM
AndresCR's Avatar
Thanks for you help, problem solved with the wheel bearings!
Old May 2, 2016 | 05:11 AM
I don't know, probably has something to do with the axle stressing the bearing under power so it's tight instead of having the inner race spin on the hub. The noise you heard was that. Glad you got it fixed!
chViETnk
Nov 26, 2013 04:34 AM
Pinksick
Nov 1, 2012 05:54 PM
dollag2k6
Oct 26, 2011 11:33 AM
GavB
Mar 15, 2011 12:31 PM
jezzder
Apr 4, 2009 08:57 AM
