HID Bulb replacing/swapping
Old Oct 20, 2008 | 11:56 PM
s3ngk4ng's Avatar
Default HID Bulb replacing/swapping
Okay, so i did some research... and found some info.
People have been saying a bit of conflicting things about the tools needed to properly swap out a HID bulb... these are what i'm confused about:
-(4mm Torx bit with the hole in the middle... could be either of the below?)
-Tamper-resistance Torx Bit
-T25 Tamper proof Torx Bit
-and the tool on
http://www.acetoolonline.com/Bondhus-12638...
Kinda confused since they come in different sizes and look sort of different (least to my untrained eye)
So which one is needed to swap a MY06 HID? And anyone have some good pics or a DIY on it? There's none on any s2k sites i've been to, heh.
Thanks!
Edit:: Well one thing's clear. The T25 Tamper proof Torx bit is for 00-01, but i'm not sure if that changed over the years? Remember, mine is MY06
Old Oct 21, 2008 | 09:55 AM
s3ngk4ng's Avatar
now that i think of it, does this belong in the UTH section? :|
Old Oct 22, 2008 | 11:12 AM
s3ngk4ng's Avatar
One last try i guess before I try the trial and error method by buying the T25 Tamperproof Torx bit and trying it out.
Anyone know if the T25 will work on MY06?
Old Oct 22, 2008 | 11:37 AM
devilchrist's Avatar
i belive tamperproof torq screw has a pin in the middle? so you'r T25 screwdriver's gotta have a hole in the middle to be even be able to fit in to the screw.
2snjnr
Oct 13, 2014 04:12 PM
wirelessguy2005
May 7, 2008 10:28 PM
vroooom..psshhh
Jul 1, 2006 08:24 PM
Bigeggroll
Feb 2, 2005 10:12 AM
Road Rage
Feb 17, 2004 07:35 AM
