HID Headlight
Old Apr 7, 2010 | 05:09 PM
sayaingokou311's Avatar
Default HID Headlight
Hey so I was wondering if anyone can help me out with this one. So I had some reconditioning to my headlights done today and the headlights came out awesome. I went to go and turn on the headlight noticed that my driver side headlight is perfect, while my passenger side started the normal warm up process where is was blue for a couple of secs, and now its pink. Any clues ideas, or anything. Checked the wiring everythings cool. Driver side normal, passenger side Pink and fail. Let me know please, I have a vacation coming up and wanna make sure if I have to either buy a new headlight or what. Thanks. PM with some responses.
Old Apr 7, 2010 | 05:34 PM
sillyboybmxer's Avatar
sounds like someone touched the bulb when they took it out or put it in.
if so the oils in the hand will cause premature bulb failure,...not sure when,.....
is the bulb pink even at full warm up???
Old Apr 7, 2010 | 05:54 PM
initial start up gives the blueish tint, then it warms up and is pink. while the driver side stays normal.
Old Apr 7, 2010 | 05:58 PM
they say that a sign of a bad ballast, or one going out,...is weird color change but since you said it happened after you disassembled the lights my bet would be on a bad bulb, id personally replace them first and see, but only after you swap bulbs from side to side to see if the change follows the bulb. If in fact it is the bulb you dont have to spend 300 on new bulbs, just pm me and i will link you to cheap oem bulbs.
Old Apr 7, 2010 | 07:39 PM
dude you freaking rock thanks man. Ill let you know peace holla!
tizbad2k's Avatar
I think we all could use a link to cheap oem bulbs. There is no reason to hide your source, they will get increased business.
Old Apr 7, 2010 | 08:02 PM
Newsflash:!!!! After 5 mins of the headlight being on, the light turns off now! Im so confused.
Old Apr 7, 2010 | 08:05 PM
ebay member "hidbulbzrus"
also has a store....just add ".com" to his name.
talked highly of on HID forums for genuine philips bulbs for a killer price. 65 for a pair
Old Apr 7, 2010 | 08:06 PM
did you touch the bulb glass???????.....at all??
Old Apr 7, 2010 | 08:08 PM
not at all man, just turned them on and it was that way today.
