High Beam Indicator
Old Feb 26, 2012 | 09:13 PM
TCU34's Avatar
Default High Beam Indicator
Hello all,
I have noticed that about 50% of the time my high beam indicator (the blue one on the dash) looks to be on when no lights are on. Its almost like it is dimly lit. Then when I go to turn on my head lights the indicator goes away. The odd thing is that it only happens about half of the time.
Anyone else have this problem? Very odd.
Old Feb 27, 2012 | 05:48 AM
modifry's Avatar
Honorary Member
You have a later model S with DRL, correct? What you describe is normal operation, the "dim" high beam indicator is telling you that the high beams are on "dim", i.e. they are in Daytime Running mode.
Old Feb 27, 2012 | 06:34 PM
TCU34's Avatar
You know what, I think this is it... but I feel like sometimes the indicator isn't on. Aren't the DRL's always on when the actual headlights aren't on?
Old Feb 28, 2012 | 10:12 AM
Ksone14's Avatar
I'm pretty sure the above post is correct. My 08 AP2 does the same. OP, next time you suspect the indicator isn't on, drive your car into a garage or some place dark and see if you can see it better.
Old Feb 28, 2012 | 01:13 PM
TCU34's Avatar
This is exactly what it is guys, the indicator doesn't come on until the e-brake is pulled down. Thanks for helping me with this!
TCU
bubsie007
Dec 10, 2013 04:06 PM
jhf2005
Nov 17, 2010 12:30 PM
ikon_vp
Dec 19, 2004 09:45 AM
WPS
May 12, 2004 07:01 AM
Venomous S
Feb 8, 2002 02:21 PM
