High Rev Issue
Old Oct 26, 2016 | 09:23 AM
titch's Avatar
And more additonal info: The owner's manual recommends that you start the car, wait a few SECONDS, and then drive slowly to warm up the engine. Once the engine's coolant reaches temp, you can drive normally. There are SO many benefits to doing it this way rather than letting it idle to warm up.
Also, you may want to drive normally for a while longer before driving the car hard. Coolant temp and oil temp are two different things .
Clearly the OP was already driving, so he's not one of the types to leave the car idling to warm up (which yes, we all know it's not as good as driving it steadily because it takes longer to warm up), the OP clearly has issue with the fact that he had to use more revs than sensible on a cold engine due to the circumstances.
OP, don't sweat it, the car would limit you much lower if there was any issues with taking the revs that high. Obviously repeated/sustained use of those revs when it's cold would cause premature wear, but doing it once or twice isn't such an issue.
Old Oct 26, 2016 | 10:05 AM
B serious's Avatar
Clearly, my post was written clearly. I referred to the OP's question by stating "to answer OP's question". The rest was referencing other post(S) recommending warming up by idling.
My additional info was...additional....info.
Old Oct 26, 2016 | 11:37 AM
Chuck S's Avatar
As far as I can see the owner's manual is completely mute on this subject. Just start the car and drive it.
-- Chuck
OVER 9000!
Dec 2, 2011 06:18 PM
StatixNWH
Feb 16, 2007 09:53 AM
specialk22tt
Dec 1, 2005 07:22 AM
S2Kay
Dec 20, 2002 09:59 AM
slbutler
Nov 20, 2002 12:43 PM
