Honda is trying to screw me...HELP
Old Aug 11, 2004 | 01:21 AM
  #51
yogi's Avatar
How many miles are on that car? The paint on the springs looks pretty fresh!
Old Aug 11, 2004 | 06:48 AM
  #52
Sideways's Avatar
[QUOTE=yogi,Aug 11 2004, 01:21 AM]How many miles are on that car?
Old Aug 11, 2004 | 09:43 AM
  #53
iLLeSTBBoY3's Avatar
Well the piston dosen't seem as black as the other ones in the middle....kinda scares me. Ummmm....Thursday we are going back to the dealership to complain about this, see what they are gonna do. I think there is damage to the piston because of the color. Look at the one thats being held, and the other ones still in the engine bay.
BTW that's not my ring, someone at the dealership..lol
Old Aug 11, 2004 | 11:06 AM
  #54
yogi's Avatar
Originally Posted by Sideways,Aug 11 2004, 06:48 AM
They can look like that after many 10s of thousands of miles.
Eh, the paint off of my springs was nearly all gone @ 50K.
Old Aug 11, 2004 | 03:34 PM
  #55
ZSAK's Avatar
one piece of advice, thru this time, retain your humor, that will make it go by better.
Old Aug 11, 2004 | 07:43 PM
  #56
Slows2k's Avatar
The piston in your pic has marks on all 4 valve reliefs. The valves made contact with it. The Picture of the valves is not as clear due to the springs being around the stems. I'm willing to bet they are bent after looking at the piston.
It is entirely possible for the crown of the piston to fail due to being hit by the valves previously. Given that the dealer has to put a warranty on the repairs, replacing the piston as well is good insurance.
Old Aug 12, 2004 | 05:47 PM
  #57
psychicadvisor's Avatar
Two things to keep in mind with Honda Customer Relations.
1) If you say "i'm never buying another Honda again, not even a lawn mower"..(actual customer quote) you can forget about any assistance. You need to give them a reason to want to help you, like you, think your a good guy etc.
2)" Honda Care" is not the same thing as Honda Warranty. Its more like an insurance company that pays claims through Honda. Still far better than a standard insurance company - any other ESP and you would be shut down already.
Peace
Old Aug 12, 2004 | 10:19 PM
  #58
yogi's Avatar
Looking at the piston again, it does look like all four valves have nudged the piston, but I don't think it's enough to cause any real piston damage, it's just broken the carbon. I can't tell in the pic if the other pistons are like that, but if all four valves hit, you are most likely going to have problems on other cylinders.
Old Aug 12, 2004 | 10:41 PM
  #59
chris_barry's Avatar
If you cannot negotiate at least partial coverage for the work your existing motor wont be too expensive to resurrect. Either fit a new piston, or get the existing one crack tested. If the valves hit hard enough to damage the piston there will be telltale cracks showing on the underside.
With a new piston/rings you would normally lightly hone the bore to assist bedding in of the new rings. Alternatively, reuse the existing rings with the existing piston if it checks out OK.
Head wise, get the valve guides checked for damage as sometimes the bent valves can flare the bottom of the guide.
Hopefully, the parts list should only be
1x piston and rings ( maybe)
1x head gasket
4x valves
4x valve guides (maybe)
Good luck.
Speedracer.
Old Aug 13, 2004 | 06:21 AM
  #60
steven975's Avatar
since you have the head off, you may want to look into aftermarket valve springs and retainers so this thing never happens again.
MannyS2K
Mar 21, 2006 09:56 AM
AusS2000
Aug 12, 2003 06:09 PM
mikamaya
Apr 2, 2003 02:46 PM
