Hondabond question
Old Aug 24, 2005 | 07:54 AM
TwiztedS2K's Avatar
Default Hondabond question
As it says, I am putting my new oil pan on. The seller sent me one tube of Hondabond. Will this cover it, or should I buy more? Thanks.....
Old Aug 24, 2005 | 08:46 AM
SenderGreen's Avatar
I don't think Hondabond is used on the oil pan. I think you are supposed to using Honda Ultra Flange Sealent II. Don't quote me, but I would at least double check. My source is a Honda Oils, Fluids, Chemicals Reference Guide (a couple years old). It only lists Hondabond 4, and Hondabond HT. However next to Ultra Flange Sealent II it states, "Thick, gray material is the only recommended product for sealing gasketless oil pans". I think the S2000 has a gasketless oil pan, I don't really know for sure. Just in case, Honda Ultra Flange sealent II part # 08718-0009.
Old Aug 24, 2005 | 09:38 AM
stefluva's Avatar
If i'm not mistaken you should only use a thin line of hondabond on the oil pan, trying to remember a previous post.
Old Aug 24, 2005 | 09:39 AM
stefluva's Avatar
https://www.s2ki.com/forums/index.php?showt...05&hl=hondabond
Old Aug 24, 2005 | 12:12 PM
TwiztedS2K's Avatar
Awsome! Thanks for the help. The new pan has been successfully installed. Everything is tightend and ready to roll. How long should I wait for the hondabond to dry before I put oil in it to test it out?
Old Aug 24, 2005 | 12:49 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
1/2 hr before adding oil with Honda flange sealant.
Old Aug 24, 2005 | 03:18 PM
Slows2k's Avatar
Hondabond is slang for the Ultraflange II. Most dealers only use the Ultraflange, and they call all the versions of Hondabond the same.
Permatex ultra grey is the same stuff as UltraflangeII
LiQUiD iCE
Feb 6, 2005 03:17 PM
Trip
Jun 17, 2004 03:17 PM
S2000boy
Jun 25, 2002 07:55 PM
mjcohen
May 8, 2001 07:13 AM
