Hood Insulator
Old Sep 13, 2003 | 03:59 PM
Nobody's Avatar
Default Hood Insulator
What purpose(s) does the under-hood insulation blanket thing serve? Any issues (like cooking the paint off of the hood) with removing it?
Old Sep 13, 2003 | 04:03 PM
ReedZ's Avatar
Former Sponsor
I lost an oil filter gasket and had and exhaust manifold fire and this insulator kept my hood from being damaged. It is much cheaper to replace than to fix the hood.
It's inexpensive and weighs virtually nothing. Why bother it? It's cheap insurance.
Regards,
J-
Old Sep 13, 2003 | 04:10 PM
Nobody's Avatar
I was thinking removing it may help with heat dissipation....obviously that's not a good think in the event of a fire, but under normal circumstances I was wondering if it would reduce under-hood temps significantly.
Old Sep 13, 2003 | 09:15 PM
jerrypeterson's Avatar
It is probably used as sound deadening material.
Old Sep 13, 2003 | 09:38 PM
xviper's Avatar
I have seen a few examples of older cars/trucks that have never seen body damage (accidents) or any other mishaps to the paint. It seems to me that when the paint does eventually begin to go bad, it usually starts on the hood. I wonder if these are a result of the insulation either having deteriorated or somehow got removed and the heat from the engine worked at baking the paint off over the years?
Old Sep 13, 2003 | 10:02 PM
slick rick's Avatar
Or it could be because it's a large, flat surface and the sun has the most perpendicular angle????.................
Old Sep 13, 2003 | 10:42 PM
xviper's Avatar
I'm sure that contributed to it but the roof and trunk lids did not show the same effects.
Old Sep 14, 2003 | 09:26 AM
Road Rage's Avatar
It is there to protect against heat damage to the hood paint from shrink/swell effect, which can cause crazing. Also, to lower noise for interior and to meet drive by noise regs.
On some cars (example 2003 Cobra) there is a mettallic backing on the hood insulator connected to a ground wire on the the fender sheetmetal. Why? Because the car has a composite hood, and AM radio static would be worse since composites do not block RF energy.
Dd you know that fiberglas was invented to house radar units in WWII just for this property?
adrs2k
Nov 7, 2009 04:54 AM
JoeyBalls
May 22, 2008 08:32 AM
BlitzSRM
Jun 9, 2005 10:13 AM
Silver Bullet
Mar 12, 2002 04:05 PM
