how to change parking lights
Recently, my parking lights in the front right headlight housing went out, i was wondering if there is any way to change it without taking the bumper off...or how to change it period. thanks for the help guys!
Turn the front of the wheel to the inside. Pull out the plastic clips at the top of the plastic wheelwell insert. This gets you access if you pull down the plastic. Turn the bottom bulb socket 1/4 turn turn counterclockwise . It's a small wedge bulb that pulls straight out. With a small midget hand and some patience it can be done. I hope this helps!
Good luck, it gets easier the more you do it!
