How to change rotors
The impact driver sold at Sears works just fine to remove the screws. If they are siezed, it is the hardest part of the job. An impact driver, used properly and in conjunction with penetrating oil (PB Blaster, Liquid Wrench), makes their removal easier.
i just did the fronts this weekend. bought the impact screwdriver from harbor freight and now the bit is stuck.... haha one time use is true.
the screwdriver worked for my passenger side but i couldn't get the screws off my driver's side. ended up drilling the head with a 1/4" bit and using a 3lb sledge to knock the rotor free.
to the OP, a 2.5 to 3 lb sledgehammer or dead blow hammer and wood block to knock the rotors loose is helpful too.
Originally Posted by CKit,Jul 3 2009, 02:45 PM
https://www.s2ki.com/forums/index.php?showt...0&#entry9585951
If you remove the brake calipers, you're 99% of the way there.
The things that I think are handy to have on hand:
1. WD-40 / liquid wrench / PB blaster to loosen the rotor face screw.
2. Cheapo Impact driver with Philips head screw for removing the rotor face screw.
3. A handheld drill with plenty of drill bits for drilling out the rotor face screw after the head of the screw gets chewed up.
It's really simple if you get the screws out in one piece. It's a big PITA if you strip the screw.
I eventually drilled out all the screws with a 1/8" bit to get things started and used a step-down bit to get a nice cylindrical cut. It took 30 minutes to drill out 7 screws. I did not and will not install new screws on any car. As long as the wheel is on the car the rotor is good to go.
BTW, my car is garaged, seldom sees rainy days, and has never seen snow...
Originally Posted by hecash,Jul 6 2009, 01:13 PM
Have you tried a fast brake pad change at the track without the screws in place?
1) I hate screws.
2) Both brands of aftermarket rotors that used on the Civic didn't come with screw holes. They had the threaded holes for removal, but no screw holes. I'm surprised that aftermarket/performance rotors for the s2k come with screw holes. I can't speak on it as I haven't gotten to that stage yet...
It all depends on what you prefer, but I have zero interest in dealing w/ screws except for removing them on the 1st rotor turn/replacement. Washers+lugs FTW!
Originally Posted by hecash,Jul 6 2009, 02:52 PM
I have not seen "performance" after-market rotors for the S2000 that are without screw holes.
As to "fast", when I pull into the paddock and need to change pads because I need to get right into a student's car or start a classroom, I don't want any extra steps. Jack it, pull the wheels, loosen upper and remove lower caliper sleeve bolt, re-seat the piston with a big-ass screwdriver, rotate the caliper up, remove and replace pads, drop the caliper and re-do the sleeve bolts, remount the wheel and be on my way.
As for the screws, I've swapped rotors at the track many times both with and without the screws installed. The only problems have been when the screws were installed and didn't want to come loose.
Not having the screws is not a problem.
