How to Clean IAC Valve
Old Aug 11, 2013 | 08:15 PM
  #101
dean.730's Avatar
If coolant leaks out of the IAC valve when it's removed, replacing the valve would then trap an air bubble, possibly compromising coolant circulation. Will I have to bleed the cooling system after doing this cleaning process?
Old Oct 20, 2013 | 06:35 AM
  #102
zmoney610's Avatar
Be careful not to ruin the clamps on the hoses that attach to the IAC. I left all hoses attached (as the DIY shows) when cleaning my IAC, but must have twisted the smaller one enough causing the 70k mile seal to be disturbed and once my cooling system was under pressure I was spraying coolant all over the place. It was an easy fix, I replaced the spring style hose clamps with screw hose clamps and problem solved (besides a painstaking coolant job). If I were to do it again or on a different car I would just take the whole piece off (meaning the two hoses as well) and clean it that way and then replace all the (what I have to imagine are one time use) clamps.
I also second the glasses or rags part. You do not want brake/carb cleaner in your eyes.
Old Jul 16, 2014 | 10:30 AM
  #103
cbs_24's Avatar
bookmark
Old May 24, 2015 | 01:09 AM
  #104
agent's Avatar
Plz don't call me retarded, but I can't find the IAC My car is European '06, and in 9 years i never had to go under the hood, so I'm totally new at this. Since my car is DBW, the IAC is not at the same place as in negcamber's post, so could you please point me in a right direction before i start dismantling everything in a fit of rage
Old May 24, 2015 | 09:14 AM
  #105
Slowcrash_101's Avatar
You're not retarded Your car is drive by wire, and the ecu maintains idle via the throttle body actuator. Hence no need for an idle air control valve. Your throttle cable turns a potentiometer called the accelerator pedal sensor, which sends a signal to the throttle body actuator.
The first picture you posted is the actuator, TPS is on the other side.
Old May 24, 2015 | 10:51 AM
  #106
agent's Avatar
I figured as much. So i guess i'll be taking off the TB and see if any gunk has built up over the years there. Hopefully only thing i'll have to replace is a TB gasket.
Thanks
Old Jun 1, 2015 | 09:40 AM
  #107
agent's Avatar
The bolts on the TB proved difficult to undo, even with the WD40. So i just cleaned the TB from the front. Relearned the ECU and all the stuttering and the idling problems dissapeared. Yay!
This is what a TB inlet SHOULDN'T look like, I blame myself for overoiling K&N filter, but after 60K miles in 9 years it was a good idea to clean it anyways.
Old Jun 1, 2015 | 10:48 AM
  #108
That's nothing, I've seen worse, shame you didn't show any inside pics, that's where you can really see the gunk. Might want to take care of your brake fluid from the looks of it though.
Old Jun 1, 2015 | 12:00 PM
  #109
agent's Avatar
I couldn't take off the TB, so didn't clean the inside. Gonna visit my buddy's shop, he should have better tools than i do Haven't done the yearly fluid change yet
Old Sep 26, 2015 | 11:17 PM
  #110
Soviet's Avatar
I just made a point of view DIY video for those who enjoy video format
[media]http://www.youtube.com/watch?v=Al-FelY21_I[/media]
