How do I lower the steering column?
Old Oct 6, 2005 | 05:35 PM
C4SxM5's Avatar
Default How do I lower the steering column?
I need to replace a broken ignition due some thieves peeling it and wanted to see if removing these 4 bolts would allow me to lower the ignition to get to the screws for the ignition (2 screws w/ broken tips on top).
If not, can someone tell me how to lower the entire steering column?
Old Oct 6, 2005 | 06:18 PM
flexer's Avatar
Hey,
I tried looking in the shop manual, and they talk about testing but not removal. Sorry. Can't be to hard to figure out though. See you at the next Utah meet.
J. R.
Old Oct 6, 2005 | 06:50 PM
Stratocaster's Avatar
Yes. The column will then drop. You might just want to loosen them as they are long. That is how you get the gauge cluster out. Been there, done that.
Old Oct 6, 2005 | 06:54 PM
C4SxM5's Avatar
thanks!
Old Oct 7, 2005 | 01:33 PM
japoneeZ's Avatar
Old Oct 7, 2005 | 05:50 PM
ideugene's Avatar
Yeah you're good with those. That computerized helm is pretty cool! Maybe I should invest
Old Oct 7, 2005 | 06:33 PM
AusS2000's Avatar
Be careful with the top cover. It clips to the lower part and the clips are easily broken.
Once you remove the bolts you can bend the column a bit and get the cover off.
rudyy
Dec 8, 2017 04:45 PM
speed bullet
Feb 21, 2011 05:46 PM
8SoL8
Jan 5, 2006 03:05 PM
Terrance914
32
May 9, 2005 08:44 AM
aznhomie
Feb 18, 2004 07:21 PM
