Taking out the instrument bezel
Old Dec 6, 2017 | 09:33 AM
rudyy's Avatar
Default Taking out the instrument bezel
I am planning to replace the instrument bezel that has some scratches, but want to do it right. Someone told me that I need to loosen the two screws of the steering column so that it can be lowered and then loosen the two screws that secure the bezel itself. So, is that the only 4 screws I need to work with to take the bezel out?
Rudy
Old Dec 6, 2017 | 10:00 AM
freq's Avatar
Qube Engineering - Documentation
Old Dec 8, 2017 | 10:18 AM
waino's Avatar
I followed this procedure and it worked great:
https://www.s2ki.com/forums/s2000-un...#entry13540681
Wayne
Old Dec 8, 2017 | 04:45 PM
zeroptzero's Avatar
the two screws are in the base of the lower trim panel, they are very easy to strip so be careful when inserting your phillips screwdriver into them as they are hard to see and they actually sit a bit on an angle which is hard to tell when working in tight confines. Once the panel is off then you have two bolts to loosen to drop the steering column, so two screws and two bolts before you can get to the cluster screws.
Soviet
May 5, 2018 02:37 PM
HighwayStar
May 15, 2010 10:41 AM
S2Kyle01
Mar 4, 2007 07:51 PM
C4SxM5
Oct 7, 2005 06:33 PM
aznhomie
Feb 18, 2004 07:21 PM
