How do you get rid of the Maint Req'd light?
Old Oct 14, 2003 | 01:38 PM
Vash's Avatar
Banned
Default How do you get rid of the Maint Req'd light?
I forgot how it goes using the +, - things. Does anyone remember?
Old Oct 14, 2003 | 02:16 PM
Decepticon's Avatar
you hold the other buttons i believe its select or trip
Old Oct 14, 2003 | 02:27 PM
trich1687's Avatar
Press and hold the " trip" button, while still holding it turn the iginition ket to the II position, continue to hold the button until the light goes off. This proceduer is also in your owner's manual but not clearly described.
Old Oct 14, 2003 | 02:43 PM
Vash's Avatar
Banned
IT WORKED!
Thanks a lot guys!
Old Oct 20, 2003 | 07:25 PM
Wildncrazy's Avatar
It doesn't work for me. What am I doing wrong?
Old Oct 20, 2003 | 07:33 PM
whites2ooo's Avatar
David, insert the key, but dont turn the key yet. Press and hold the "Trip" button. While still holding down the Trip button turn the key to the "ignition" position. wait until the Maint Req'd light goes out and your done.
Old Oct 20, 2003 | 07:58 PM
Wildncrazy's Avatar
How long does that take? I have done that and waited up to 10 seconds.
Ignition position is the full on position right?
Old Oct 20, 2003 | 08:11 PM
whites2ooo's Avatar
hmm..? Somethings wrong...? The light should take no longer than 10 secs. Ignition is the position that turns on the tach and fuel, temp gauges...
It should've worked. Lets try something else: (I'm trouble-shooting with you here David) Try inserting the key and turn "one click". From here press and hold the trip button. While still holding the button turn the key to the Ignition.... Wait about 10-15secs. or til the light goes out.
Hope that helps.
Old Oct 20, 2003 | 08:21 PM
Wildncrazy's Avatar
That worked, but it took a full 15 seconds.
I had already reset the ecu as well and that had no effect.
Thanx. I have had that light on for the past 1,000 miles (at 15k)
Old Oct 20, 2003 | 08:31 PM
whites2ooo's Avatar
No problem..........dont forget next time...
