How do you remove the DRL's?
Old Oct 6, 2010 | 02:50 PM
bluerennfahrer's Avatar
Default How do you remove the DRL's?
been searching but couldn't find it.
maybe didn't search hard enough.
but was wondering if there's any way that i can turn off the DLR on my 07
thanks.
Old Oct 6, 2010 | 03:03 PM
spets's Avatar
It is DRL, not DLR.
Old Oct 6, 2010 | 03:22 PM
retvet's Avatar
Why do you want to turn off your RLD?
Old Oct 6, 2010 | 03:27 PM
because i don't like the LRD
the RDL doesn't look too good on the car
so back to the question, is there a way to turn off the LDR?
Old Oct 6, 2010 | 04:05 PM
spets's Avatar
I believe you can pull a fuse to turn it off. But I don't have DRLs so I can't be more specific.
Old Oct 6, 2010 | 04:24 PM
spook's Avatar
I like RLD GLD pretzels.
Old Oct 6, 2010 | 06:18 PM
Slows2k's Avatar
Fixing your title. Back on topic people
Old Oct 6, 2010 | 06:31 PM
spook's Avatar
Remove fuse 14 under the dash.
s2000maniac's Avatar
unplug the high beam connector. but you wont be able to use your highbeams. thats how i did it on my lexus GS300.
Old Oct 6, 2010 | 07:32 PM
CarbonCrew's Avatar
thanks.
Odd.. I was trying tracking down a solution tonight using the wiring diagrams from the service manual. As I understand the schematic, voltage to the high beam bulbs is controlled by the DRL Control Unit, modulating between low voltage for the DRLs and 12v for the high beams when commanded. Some research has shown that the DRLs are disabled when the parking brake is activated. This agrees with the schematic as the DRL Control Unit has parking brake input (Green wire, PIN 6). I think, that the DRLs can be disabled by breaking this connection and taking PIN 6/Green wire to ground.
Havage
Apr 21, 2017 09:26 PM
adelgigs
Aug 27, 2011 05:46 AM
Sr2000
Aug 24, 2011 11:12 AM
loftust
Dec 17, 2010 02:28 PM
ULTRA_KILL
Feb 14, 2007 05:27 PM
