How to get inside the trunk
Old Feb 11, 2024 | 09:07 AM
jchau123's Avatar
Default How to get inside the trunk
Is there a way to get inside the trunk from the interior? Removing panels behind seats?
Electrical connector for the trunk has been disconnected so button inside the compartment dont work.
Latch for the key is not connected so key doesnt work.
I need to manually hit the trunk release.
Old Feb 11, 2024 | 10:39 AM
windhund116's Avatar
If the latch isn't connected, shouldn't the door open?
Old Feb 11, 2024 | 12:06 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Through the interior.
There is a glow-in-the-dark manual release lever.
Old Feb 11, 2024 | 12:13 PM
jchau123's Avatar
Theres a rod connected to the keyhole where the trunk is, so when you turn the key the rod extends and opens up the trunk. That rod isnt connected.
Old Feb 11, 2024 | 12:20 PM
noodels's Avatar
tin opener
Old Jun 9, 2024 | 04:43 PM
danlnyc's Avatar
I'm really embarrassed to update my thread with this but it turned out to be a dead/low battery. I've had my car sitting up on my quikjack for the past month. I didn't think it was the battery because the light in the trunk would turn on.
My cluster is removed and the steering wheel column is loose so I had to remove the start button from the cluster, put on the jump starter and voila, everything works fine now.
Sorry folks.
Old Jun 10, 2024 | 05:16 AM
Chuck S's Avatar
Don't be sorry it got us all thinking how we'd do this if it were to happen. Glad you didn't have to remove most of the interior to tunnel in.
-- Chuck
WheelNut
Aug 31, 2010 12:08 PM
Almostlude
Feb 25, 2010 05:25 AM
sam_spider
Feb 8, 2010 11:35 AM
loudes13
Sep 25, 2006 09:17 AM
s2kjb
Aug 19, 2006 11:07 PM
