How to install the AEM fuel regulator
Something similar Aus, but Comptech's FMU makes it easy by adding using AN fittings and the remote mount regulator. If you are using the rail mounted regulator, you will have to install the gauge on the pressure/feed side. The Fuel supply hose attaches to a steel hard line on the frame rail. I don't see the probability of anyone flaring the hard line who wouldn't tap the rail. So you'd have to use some hose barbs, a T fitting, anothe hose to the B&M gauge.
yah i think that is wut i am going to have to end up doing.....and while its out and ready...just tap into that one...and then take other one out and put this one on with my gauge and aem fuel pressure regulator
Originally Posted by Slows2k,Feb 28 2005, 06:50 PM
IF you run a Mechanical fuel pressure gauge in the car, you MUST use a fuel pressure isolator. It is a major safety issue to have fuel inside the passenger compartment. If you do go to any track event (drag or road course) with a tech inspection you will not be allowed to run.
but you are right, an isolator must or should be used when running a mechanical gauge inside.
by the way i have searched it up and that is where i did find the str fuel rail...i am asking people what they think of it and if anyone is using it....i also wanna know would i hook up a fuel gauge directly to it...or woudl i still have to tap it for that one as well
Nicely edited!
If you read your posts it says:
You don't ask for an opinion, you ask if there is a fuel [rail I suppose] made for our car [or some shit]. Perhaps the term you edited out of your reply applies more to you.
That said, here's an opinion for you. You don't need it.
Just purchase a second OEM.
so i heard that there is a fuel made for the honda s2000.....str or some shit makes it....anyone use those...heard of those...? or know any company that makes a fuel rail for my car?
