How to install the AEM fuel regulator
Old Jan 28, 2005 | 12:49 AM
Reds2kracer's Avatar
Default How to install the AEM fuel regulator
Hey guys, I just bought a Aem fuel regulator and need some help on how to install it plus adjusting it to stock. Can anyone help out on this subject? I never done it before but I can if shown how to, any hint, ideas, help will be appreciated. Thanks...
Old Jan 28, 2005 | 01:25 AM
AusS2000's Avatar
Doesn't is just bolt onto the fuel rail in place of the stock regulator? Mine does.
Then you need to attach a fuel pressure gauge to the rail (usually in place of the damper) and set it to between 47-54psi at idle with the vacuum line crimped.
Old Jan 28, 2005 | 05:11 AM
Sideways's Avatar
Be very diligent with the O-ring and the screws. They are easy to drop and impossible to find. If you end up needing new O-rings you can get them at Home Depot for less than a quarter. The dealer wants several dollars. The proceedure takes about 5 minutes.
As far as the pressure, you can probably drive it conservatively until you get the pressure set. Any Honda mechanic will have the pressure gauge. I drove mine and when we checked it we found 37 psi. There is a set amount for each turn of the adjustment screw...and I don't remember but I think it was 5psi per 360 degree turn. Check it out and let us know if it is otherwise.
Old Feb 27, 2005 | 11:46 AM
Stko0k's Avatar
where does the fuel gauge goo again...the place of the damper...which is where?...can i get a pic please?
Old Feb 27, 2005 | 12:44 PM
Slows2k's Avatar
The honda special tool pressure gauge attaches to the fuel rail at the pulsation damper. The pulsation damper is the large "nut" that holds the fuel feed line on the rail.
Many people have removed the fuel rail and tapped it to permanently install a pressure gauge.
Old Feb 27, 2005 | 03:56 PM
Stko0k's Avatar
i have a something like a B&M fuel gauge....how would that install onto my fuel rail....someone told me on my fuel filter...but isnt that on the bottom....i am kind of confuzed about wut i need to do with this fuel gauge.....lol....
Old Feb 27, 2005 | 04:18 PM
Slows2k's Avatar
There is NO servicable fuel filter in a S2k. you will have to remove the fuel rail to drill and tap the rail to attach the B&M gauge.
Old Feb 27, 2005 | 06:00 PM
EriS2k's Avatar
Yes a PIC! jejej
I got My Auto Meter Fuel Pressure Gauge in the my Room waiting for Install
Old Feb 27, 2005 | 11:52 PM
Stko0k's Avatar
i also do not want to tap permanently into my fuel rail.....soo...need to be another option
Old Feb 28, 2005 | 04:26 AM
Venomous S's Avatar
I tapped my fuel rail permanently and running a Fuel Pressure gauge inside the car
