how much brake fluid?
I will be changing out the pads, rotors, and fluid this week. I was wondering how much fluid I need to pick up for the job. Also any recommendation on type of fluid would be appreciated. I am wanting to go with a fluid that will withstand autocrossing and the occasional track day. Thanks in advance.
Scott
Scott
RR,
What time interval would you suggest for fluid changes if one were to go with a DOT 4?
What do you use as a "reverse bleeder device"?
I did a Yahoo search and came back with this....what do you think?
http://www.moccsplace.com/images/brakes/bl...der/bleeder.htm
You should be fine with one liter for a complete flush and bleed, order two liters if you want to be completely covered.
Any good high quality fluid such as ATE or Motul should be more than sufficient to withstand auto-x and track use. Stay away from the factory fluid as the wet boiling point is much (over 100 degrees) lower than a good performance fluid.
The S2KI store sells a variety of fluids that should fit your needs if you can't find the appropriate fluid locally. Just click on the marketplace link at the top of the page if you want more info.
Originally posted by honda606
RR,
RR,
http://www.phxsyss.com/products.asp?id=1
Fluid DRY WET
Castrol LMA DOT 3/4 446 311
Ford Heavy Duty DOT 3 550 290
ATE Super Blue Racing 536 392
ATE TYP 200 536 392
Motul Racing 600 585 421
Castrol SRF 590 518
Performance Friction 550 284
