How to replace door window?
Old Jun 20, 2007 | 07:50 PM
silvers2k01's Avatar
Default How to replace door window?
I tried to search, but couldnt find a DIY thread. I scratched it pretty bad while removing tint, i bought a used glass from the junkyard and plan on installing it later
Old Jun 20, 2007 | 08:04 PM
RedY2KS2k's Avatar
Sounds like you get to contribute the DIY on this repair.
Old Jun 21, 2007 | 05:18 AM
bubbs's Avatar
It's not too hard. I replaced the whole door and swapped out the glass.
You have to take off the panel. Then there are about 3 places where the glass is attatched, the front, middle and back. It's really pretty easy.
If you get the shop manual it will show you everything. You can get it on ebay for less than $5.
JB
Old Jun 21, 2007 | 09:23 PM
Avionics86's Avatar
If you did not remove the old glass yet mark your settings with a marker before you remove everything.
Old Jun 21, 2007 | 09:33 PM
jdmgpw04's Avatar
its easy...
Old Jun 21, 2007 | 09:54 PM
00CivicSi's Avatar
Originally Posted by jdmgpw04,Jun 22 2007, 01:33 AM
its easy...
Way to contribute.
Old Jun 21, 2007 | 10:00 PM
jdmgpw04's Avatar
Originally Posted by 00CivicSi,Jun 21 2007, 09:54 PM
Way to contribute.
not that easy to explain but easy to do
i agree with Avionics86
make sure its align i suggest you start pulling the side panel just a start, so you know what your up to...
good luck...
oh btw make sure its align otherwise its going to make some crazy noise...
wokadowokado
Jun 16, 2014 12:03 PM
macr88
Body
Jan 14, 2010 09:43 PM
vvs
Aug 1, 2008 02:30 PM
LUV2REV
May 15, 2005 08:58 PM
LUV2REV
May 15, 2005 03:07 PM
