How to replace rear control arm bolt?
Old Mar 28, 2008 | 05:10 PM
S2FARSI's Avatar
Default How to replace rear control arm bolt?
I had to replaced one of the two bolts securing the rear upper control arm on the passenger side (the previous bolt somehow fell out) with a brand new OEM bolt. I now hear a crap load of noises when I drive over dips/bumps from the same location of the car. When I installed the bolt I just screwed it in. I am posting because I wanted to know if grease or some other lubricant was supposed to be added during the installation process. I looked in the Helms manual but nothing is stated. Can anybody shed some light on this?
Old Mar 28, 2008 | 05:23 PM
Avionics86's Avatar
Might try to preload it and use proper torque.
Old Mar 29, 2008 | 09:16 PM
S2FARSI's Avatar
How do I preload it? Jack up the knuckle before/while installing ?
Old Mar 31, 2008 | 01:06 PM
S2FARSI's Avatar
anybody?
Old Mar 31, 2008 | 04:38 PM
jetboater's Avatar
just looked it up in the Honda S2000 service manual--says to preload it, after you lightly tighten the bolts--raise the suspension to load it with the vehicle's weight before you tighten the upper arm bolts---- torque specs are 132N-m or 97.6 lb/ft
no lube or grease is mentioned.
Old Apr 1, 2008 | 10:52 AM
S2FARSI's Avatar
Thats what I did. Still makes noises. God damn this.
Old Apr 1, 2008 | 06:13 PM
INTJ's Avatar
I'm looking at this myself to avoid the dreaded s2k binding. I have a mild antisieze from permatex for brakes (looks identical to the honda pad grease). I plan on lightly dressing the shaft of the bolt, but not getting anything onthe threads for a proper torque reading.
Old Apr 1, 2008 | 09:06 PM
S2FARSI's Avatar
Whats that?
Old Apr 1, 2008 | 11:15 PM
frofro24's Avatar
Preloading, antiseiz and proper torque is always a good thing as mentioned above by others. I use antiseiz on almost everything, it can make a world of difference when removing a bolt. It is important you coat the entire bolt. (including the threads) You might want to check the bushings and other parts tied into the suspension. I had a metallic noise some time ago, I got under the car and found it to be my endlink. Some how it came loose and needed to be snuged up.
ViperASR
Dec 14, 2013 02:26 PM
bruthaboost
Sep 10, 2013 08:03 PM
SCZ4
Jan 17, 2013 11:52 PM
vjarnot
Nov 25, 2010 09:07 PM
ToeKneeC
Mar 10, 2007 10:48 AM
