How to strenthen the engine for nitrous
My list had most of the possible protections. You don't need all of them to be "safe", especially with a 50 shot. Many folks mod their nitrous car by upping the dose. Then they blame nitrous if something went wrong. Most of the engine burn downs I have heard about are kinda predicatable. Note that some of the suggested nitrous protection things are rather simple. Like run colder plugs properly gapped. Decent gas. A reliable install.
Stan
Stan
Nitrous done the right way and warrantied by the installer...... haha, not even a 1000. I'd say 1500-2000. If you include the labor, and all the goodies. Its more expensive than most believe.
Brandon
Brandon
>>>Nitrous done the right way and warrantied by the installer...... haha, not even a 1000. I'd say 1500-2000. If you include the labor, and all the goodies. Its more expensive than most believe.<<<
Yeah. Nitrous can be bought cheap and is often installed by folks who can barely operate a hammer. Of course they decide to start out with a big nitrous shot.
Nitrous should be installed with safeguards and by folks that follow directions or shops that have done many sucessful installs. Cheap Nitrous is sorta like buying a turbo and not requiring a manifold, boost control, gages, fuel enrichment and so forth.
Do it right and you'll be faster than an SC S2000 with maybe a 60 shot.
Stan
Stan
I.M.H.O. IF ya can't install the kit yourself then Nitrous is not for you. There is constant up keep to make sure all is working properly. Its not a get it installed and forget about it.
E30m3 is correct with all the safety features. But if ya don't get
a window switch to control when ya spray at what rpms, I would suggest ya use a moment switch instead of the w.o.t. switch to activate the Nitrous. It easy to bounce the rev limiter
in the s2000. I have my moment switch located where I have to use my shifter hand to press it. So i spray til about 8500 rpm then Release button and shift ....that way the chance of me hitting the rev limiter while spraying are greatly reduced.
>>>It easy to bounce the rev limiter<<<
Most OEM rev limiters cut fuel by turning the injectiors off until revs drop. Imagine if you were running a dry shot which feeds the regular PLUS nitrous related fueling. Not good if the nitrous keeps spraying when there is no fuel... That's why a window switch would help. Down low, it prevents nitrous hits at say 1200 RPMs. Which would bend rods.
Stan
Stan
Ludeboye1
Nov 12, 2018 07:54 AM
we thought it was the rod bearings, replaced them, still clacking
