I need help with alignment specs...I just got my
Old May 31, 2005 | 06:12 PM
blackfx35's Avatar
Default I need help with alignment specs...I just got my
Front:Left
-0.6 Camber
5.5 Caster
-0.01 Toe
Front:Right
-0.6 Camber
5.4 Caster
-0.01 Toe
Rear:Left
-1.4 Camber
0.20 Toe
Rear:Right
-1.7 Camber
0.20 Toe
I think I'm off on rear...what do you guys think...?
Old Jun 1, 2005 | 05:52 PM
blackfx35's Avatar
46 and still not a single reply
Old Jun 1, 2005 | 07:23 PM
Clayman's Avatar
It depends what you mean by "off." I've got mine set to .21-.22 and -1.5 camber in the back. My setup handles like tha bomb. Tire wear has been perfect, and stability at high speeds is great. If it feels good to drive, it might be OK. Just keep an eye on tire wear to make sure it's even.
Old Jun 2, 2005 | 01:28 AM
m@dm@n's Avatar
Banned
does anyone have the stock specs?
Old Jun 2, 2005 | 07:51 AM
Heathaze's Avatar
From the Service Manual:
Camber Front: -0deg 30' +- 30' (+-10' at adjustment)
Camber Rear: -1deg 30' +-30' (+-10' at adjustment)
Caster Front: 6deg 00' +-15'
Total Toe-in: Front 0+-2mm (0+-0.08in.)
2000-2003 models Rear: 6+-2mm (0.25+-0.08in.)
2004-2005 models Rear: 3.7+-2mm (0.14+-0.08in.)
Old Jun 2, 2005 | 08:07 AM
mbilderback's Avatar
Well, just crunching numbers from the posts here:
Front:Left
-0.6 Camber I'd say extreme on this, says that at time of adjustment you want +-.1, this is -.3, the far end of in spec.
5.5 Caster Out of spec, 5.85 is the minimum front camber, 6.15 max.
-0.01 Toe In spec, but if he can get to -.01, why can't he zero it out?
Front:Right
-0.6 Camber Same as my comments on left.
5.4 Caster Ditto.
-0.01 Toe Ditto.
Rear:Left
-1.4 Camber Extreme end of adjustment spec, I'd want him to get a bit closer to -1.3.
0.20 Toe Within spec.
Rear:Right
-1.7 Camber Out of Spec entirely, max neg camber should be -1.4 at time of adjustment, it's even -.1 further out than it should be at all.
EDIT: Was this a dealer? Who did the alignment?
Old Jun 2, 2005 | 08:59 AM
cdelena's Avatar
The alignment is pretty close.. most would not fool with it. A little extra negative camber won't hurt.. it is hard to get caster right on, and the toe looks pretty good. Some dealership personnel cannot get that close.
Old Jun 2, 2005 | 03:24 PM
blackfx35's Avatar
Thanks guys for your help.
The dealer did the alignment.
I'm so pissed off because not only I paid $90...they also scraped my front lip.
Old Jun 2, 2005 | 05:39 PM
C4SxM5's Avatar
here are my #'s, BUT i don't know if they are correct either...
FromaDB2toanAP1
Nov 11, 2011 06:55 PM
h2k
May 27, 2009 10:01 AM
S2K:-)
Apr 13, 2006 08:31 PM
TunedS2000
Jan 14, 2005 07:06 AM
RazorV3
Nov 14, 2004 08:18 AM
