i neeed help asap!
piston heads? i highly suggest you take this car to someone who knows what theyre doing, because, no offense, it doesnt sound like youre too mechanically inclined and if you mess up a valve job, youre going to be buying a whole new motor
Originally Posted by s2kking' timestamp='1339252401' post='21768177
I have another question ??? When valves get bent do I have to change piston heads
if so would the piston make noise??? Nd would there be smoke coming oout of the exhaust ???
if so would the piston make noise??? Nd would there be smoke coming oout of the exhaust ???piston heads? i highly suggest you take this car to someone who knows what theyre doing, because, no offense, it doesnt sound like youre too mechanically inclined and if you mess up a valve job, youre going to be buying a whole new motor
I'm not the one fixing it, I took it to a mechanic.. I just wanted to get some info
A bent valve wouldn't cause piston damage unless it dropped. Are you continuing to run the engine?? Bent valves can definitely cause smoke. Unburned fuel from the valves not sealing properly, oil leaking past the valves into the combustion chamber, you name it. I would stop running the engine, you are risking further damage. GET IT FIXED!
so as of right now i have to wait for them to take the head off nd see whats the damaged...=/
also my car doesnt smoke and my exhaust does make a popping sound when the car finally idles, another thing my boy was driving behind me (when this first happen) nd he said that it smelled like unburned fuel...
sounds like a nightmare ...sucks to hear after one day of ownership this happened to you ...hope u hv better luck down the road with this awesome little car we call an S K ...mines has been very good to me "i'm on my second" put over 140k trouble free miles on my cars I can tell u the s is the beast car i've ever owned ...i hope u get to feel the same way soon ...this site may be the best resource u hv use it ...and learn ...best of luck
thnx man
and you are right about this site
tokyo_james
Apr 11, 2004 08:20 PM
