idle is going crazy
Old Jul 12, 2008 | 06:59 AM
wuchan01's Avatar
Default idle is going crazy
Everytime i start the car, i let it warm up and when it gets down to 1000RPM's they start to spike up to 2800RPM's and it keeps doing this every 3 seconds or so and it doesnt stop, even though when i turn on the AC it settles at 1500, but when i touch the throttle it goes back to the 1000-2800 fluctuations. I have doen the MAP wack, ive reset the ECU, and i have no CEL. Please help as the car is not very driveable.
Thanks in Advance.
Old Jul 12, 2008 | 09:27 AM
EVAN&MONICA's Avatar
IDK for the sick avatar, good luck
Old Jul 12, 2008 | 09:30 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
IAC valve is sticking, guaranteed 100%.
Remove and clean, lube with WD40.
Old Jul 13, 2008 | 01:29 PM
wuchan01's Avatar
^Thanks, i took it out and cleaned up the carbon build up with WD-40 and put it back in, but it still kept having the issue, so i ended up chancing the IAC. Thanks for pin-pointing the problem Billman
abarca54
May 1, 2014 12:10 PM
slowpokeS2K
Oct 21, 2012 05:42 AM
kalibo
Sep 21, 2007 09:07 AM
razzele
Oct 5, 2006 04:50 PM
mumbler
Jul 17, 2006 10:36 AM
