Idle question
Old May 31, 2008 | 01:54 AM
Silver5656's Avatar
Default Idle question
my car idles at 1000 rpm even after it is warmed up. After 10 min or so of light driving, after an hour of pushing it, and anything in between, it idles at 1000. I think maybe ONCE i saw it dip to 900 for a sec but then back up to 1000. Is this the norm?
Old May 31, 2008 | 10:49 AM
chuhsi's Avatar
mine idles at 1k rpm when warm
Old May 31, 2008 | 12:51 PM
FilthyAp2's Avatar
Yeah same here but im not sure if i have lifter probs or not, i gotta take it in to the dealer but once in a while ill come to a complete stop and the car will drop to 300 shake for a sec or two then jump back up... anyone else have this issue?
Old May 31, 2008 | 02:30 PM
Silver5656's Avatar
hmmmmm its good to know im not the only one idleing at 1k......stoner, is ure ac on? do you have a stereo system? these can put a drain on ure batts which can drain ure alt thus the shudder
Old May 31, 2008 | 02:57 PM
Kdlopez01's Avatar
My ap2 at start up is at about 1543rpm depending on outside temperature but after warm up sits about 750-850rpm thats what my VAFCII tells me
Old May 31, 2008 | 04:08 PM
FilthyAp2's Avatar
No AC is not on...... You can always play around with IDLE control on the TB and adjust it if its off.
Well the shudder i was talking about i just fixed by doing the DIY IAC clean out
Here is a link for those that might be intrested!
https://www.s2ki.com/forums/index.php?showt...&#entry10624891
Old May 31, 2008 | 04:09 PM
FilthyAp2's Avatar
Ill belive the VAFCII rather than the OEM Gauge..... Those things are usually off by 100 - 200 rpm
Old May 31, 2008 | 05:13 PM
skeithr's Avatar
stoner, i get the drop down to 3-4 hund. every now and then too, let me know if you find out if this is normal
Old May 31, 2008 | 08:06 PM
FilthyAp2's Avatar
Its normal in a sense..... Over time your IAC will get built up blow by and needs to get cleaned out, your ECU will try and adjust itself to these changes but when there is too much built up it wont process everything correctly and thats when you get the shudder. Along with other reasons like the MAP sensor, this too can be fixed by cleaning the plug (not the sensor) and try putting a zip tie around it to make sure its a secure snug fit. I would try the IAC clean up first and drive around a couple of days to see if it come back.... I have 70k on my 04 and it first started doing this at around 55k. I didnt think much of it at the time but it just started doing it more often till i decided to research it on here.... Thanks to the other guys here on boards i fixed it..... Check out that link i posted on my previous post.... All the info you need on this issue is on there and talked about. Hope it helps and GL.... Oh one more thing, if you decide to clean it out make sure you take out the little rubber gasket that goes around it, its not carb cleaner friendly.
JC
Old Jun 1, 2008 | 10:30 AM
skeithr's Avatar
thanks, my 02, has 55k on it and it just started i guess its normal for it to happen around then, appreciate the help stoner. drive hard and safe
Rice069
Dec 5, 2012 08:49 AM
s2000maniac
Aug 6, 2010 09:37 PM
s2k83
May 20, 2009 11:28 PM
akilbrid
Feb 14, 2009 06:45 PM
Nside
Oct 22, 2001 07:43 PM
