Idling Problem at stops
Old Mar 17, 2006 | 01:43 AM
REVZ TO9's Avatar
Banned
Default Idling Problem at stops
How come right when I start my car or even when I come to a complete stop with my foot on the clutch and brake all the way down at the same time that first few seconds after I completely stop, the car makes this idling noise like its about to die and the shift knob kinda shakes, then sounds and goes back to normal afterwards? How do I fix this? Its kinda scary. I know my throttle body is clean, cuz I looked inside it. Thanks!
Old Mar 17, 2006 | 06:50 AM
Wisconsin S2k's Avatar
It's not a "problem". Often the ECU gets "confused" particularly when your weather changes, or temps get into the 30-40 range. First, DO NOT give it gas when it "stalls". This will only make it worse.
Give it a few days, and it will likely correct itself. If it doesn't, try the map sensor "whack" which is in the FAQ at the top of this forum.
Old Mar 17, 2006 | 09:07 AM
kent-k's Avatar
seems like everyone is getting this occurence lately.
Old Mar 17, 2006 | 09:30 AM
that's because pretty much all S2000's do it. mine does it all the time when the weather changes drastically. it's nearing spring, so a lot of places are going through temperature changes.
abarca54
May 1, 2014 12:10 PM
Sub_01
Sep 19, 2008 07:46 AM
REVZ TO9
Mar 3, 2006 08:52 PM
Saxo Boy
Dec 21, 2005 08:20 AM
VTECAZ
May 28, 2003 06:58 AM
