Ignition coil preferences
Old Jul 17, 2018 | 08:34 AM
  #31
Pinky's Avatar
Originally Posted by RolanTHUNDER
I see. Same with my '00 coils. They went out after a solid 17 years! I think the main reason was that excessive oil basically drowned coil number 3 in particular killing it and causing the rest to follow. Previous macs at Honda did not even notice this when the car went for dealer services and expensive stamps in its book...I promptly cured that by replacing the VC seals with brand new OEM ones then a set of used (but lower mileage - 100k miles) coils from an '01 S2K. Misfire gone as a result though I don't know how much longer they will last.
Honestly every 10-15 I would rotate 1 & 4. Then 2 & 4 and so on. Reason is I found that the #4 coil can get excessively hot over time and rotating them might help. Watch for discoloration of the coil pack too.
Old Jul 17, 2018 | 10:54 PM
  #32
RolanTHUNDER's Avatar
Good advice Pinky. I've noticed that discoloration as well. I attributed it to oil burning the coil when it seeps passed the plug hole seal (old, hard seals).
Old Jul 18, 2018 | 06:23 AM
  #33
jackmugen02's Avatar
Former Sponsor
So that is why I see people number the ignition coils on this engine.
What is the cylinder order if you are standing in front of the engine?
A few companies(chasing J's, Circuit hero and Ssworxs) make vented ignition covers for the F20/22 engine made out of titanium, aluminum, stainless steel or steel.
Old Jul 18, 2018 | 07:18 AM
  #34
Pinky's Avatar
#4 is at the firewall.
Old Jun 22, 2022 | 01:35 AM
  #35
Just a heads up boys. One out of 4 Amazon bought Denso "made in Japan" 673 2301 coils burned out on me. I bought an identical replacement and it too burned out on the first pull at only 7k rpm. I'm supercharged.
This makes me so mad that I want to buy the actual, no questions asked genuine AP2/K20 2004-5 coils from Majestic. 30520-RRA-007 $69 each.
Can't be a wiring or any other kind of electrical issue since the car works well and my old OEM coils still run but are dying out at 8k rpm pulls...
Old Jun 22, 2022 | 03:57 AM
  #36
Slowcrash_101's Avatar
I'm running NGK coil packs I got on Rock Auto 2 years ago. They are made in China and still work just fine.
Old Jun 22, 2022 | 04:48 AM
  #37
Coincidentally I'm looking at those online now!
NGK Coil U5099 for early AP2 and K20 2004-5. $54.58 on two step performance. For 15 bucks more I'd rather get the OEM ones but still, I like and trust NGK.
Where'd u buy yours?
Old Jun 22, 2022 | 05:33 AM
  #38
Chuck S's Avatar
Just for information the part number for the 2006-09 (DBW) engines is 30520-PZX-007. $150 each...
-- Chuck
Old Jun 22, 2022 | 06:10 AM
  #39
-- Chuck
That's correct. DBW coils should not be used on 2000 to 2005 models though, in case anyone was wondering
Old Jun 22, 2022 | 03:43 PM
  #40
cosmomiller's Avatar
Top Answer: 1
Not just car parts either. China knockoffs have flooded the world and Amazon is easy pickings for counterfeit goods. When it comes to something that demands quality (proper air breathers, OEM parts, medical equipment, firearm stuff, medications/supliments-knockoff heart worm and flea stuff for dogs) You should go to a known reseller or the manufacturer website to order. You may pay a little more but it is for the USA and you get the quality you need. I am very suspicious of a lot of products I see on Amazon.
BTW, anything made in Taiwan is of very good quality, I have found over decades.
