Inner engine parts.
Old Mar 16, 2003 | 11:12 AM
OneInsaneS2000's Avatar
Default Inner engine parts.
Ok. I have a question that I know nothing about and I need some pro help. Im looking into buying a turbo charger for my S2000. Im looking into buying the Stage 6 - Stage 2 turbocharger kit. The kit is recommended to run at 7 psi with stock internals. Can all of you tell me what parts of the inner engine I need to change to higher performance, what brand parts I should buy, and how much they will cost around. I know I want to change to higher performance Cams, Rods, Pistons and Gaskets. What brands do you guys suggest and if possible put a estimated price next to each part. Thanks a lot guys. Im not too smart with inner engine parts .
-Adam
Old Mar 16, 2003 | 12:17 PM
Wesmaster's Avatar
The only cams out are Toda.
As for getting a built F20C you need to contact cjb80 about a Mike Simon motor. With your stock motor as the core a built Mike Simon motor will run you $6,800. You could potentially just get a built short block for about $3,500-$4,000 (I assume). Read this thread for more information.
Old Mar 16, 2003 | 02:03 PM
I thought JE made forged Pistons for s2000?
Old Mar 16, 2003 | 02:25 PM
Wesmaster's Avatar
They do...what's your point?
Old Mar 16, 2003 | 02:50 PM
lol sorry about that. Im just really tired. I thought you were talking about pistons when you said the only cams are Toda. heh sorry about that. If Im going to be doing turbo do you think that, Toda Cams, JE Pistons, and a good quality set of rods and gaskets would be enough to raise a turbo boost to 14psi?
Old Mar 16, 2003 | 03:02 PM
Wesmaster's Avatar
There seems to be a little secret to getting JE pistons to work well in an S2000. Mike Simon has worked out all the issues and is producing motors that handle over 20 PSI. So, with a Mike Simon motor, 14 PSI would be a cake-walk.
Old Apr 24, 2003 | 08:52 PM
SuzukaS2K's Avatar
[QUOTE]Originally posted by Wesmaster
[B]There seems to be a little secret to getting JE pistons to work well in an S2000.
Old Apr 24, 2003 | 08:57 PM
SuzukaS2K's Avatar
Do you think if I just throw in a set of 9:1 JE pistons and forged rods.........the car will run good with the turbo? Are there any advantage or disadvantage when i do this?
Old Apr 24, 2003 | 09:07 PM
Wesmaster's Avatar
[QUOTE]Originally posted by SuzukaS2K
[B]Do you think if I just throw in a set of 9:1 JE pistons and forged rods.........the car will run good with the turbo?
Old Apr 25, 2003 | 05:18 AM
S2000_Europe's Avatar
SuzukaS2K
Still waiting for your impression with the UR turbo that you recently installed
