installing new engine
Old Apr 23, 2010 | 12:15 PM
crank's Avatar
Default installing new engine
hey guys, i am installing a new complete f20c into my 2000 ap1, i took the engine out and did so with the head off and transmission still connected. I removed it from the top LOL . Anyhow, i am wondering if anyone can give me some good advice as to how i can pull off the install the most efficient way. The engine is going to be complete, just the tranny will be disconnected(however i do want to put it in as one, but i read its not possible). I have searched and i found a write up but i didnt really like it at all. I can buy a haynes manual but im just poking around first !! thanks guys !
A before pic for good measure
**how its been for the last 2years lulz,**
i took good care of it tho, conditioned all rubber with water based sillicone and all, the car is a 2000 with 112,000 miles, just bought a 2002 f20c1 with 600 original miles, or so i was told and carfax last repoted 10 miles on the odometer. should be here within the week.
OLD motor, scored cylinder walls, cracked retainers. Everything else is in great shape tho.
Old Apr 23, 2010 | 12:16 PM
crank's Avatar
i will take pics and post them when i do the swap ! car has been sitting since 2008 due to lack of funds LOL im just a poor college student. There is also a tiny bit of OLD fuel in the tank, do i need to drop the tank to drain it ? any advice on that too would be awesome !
Old Apr 23, 2010 | 12:29 PM
sparrow's Avatar
I just did this a couple weeks ago and I suggest dropping in the motor fom the top. But when you do this hook up all the wiring before the engine is fully down in the bay. The extra slack will make it easier to get to everything.
Once you lower the engine and bolt up the motor mounts then jack up the car as high as you can and install the trans from the bottom. Hope you have some friends to help you .
Old Apr 23, 2010 | 12:32 PM
crank's Avatar
ya i will be doing it from the top so i dont have to drop the subframe. dam how the hell am i gona get the infamous top tranny bolts lol, and what is the sequence for the engine mounts ? i saw it yesterday i just forgot where.
Old Apr 23, 2010 | 12:34 PM
crank's Avatar
my fingers and body are so sore from polishing/cleaning EVERY nook and crannie before i pop it in !! the pic of my bay above^^ is before i cleaned it. I will post more pics in a bit its looks so niceee !
Old Apr 23, 2010 | 12:38 PM
fatjoe10's Avatar
you will have to drop the subframe to get to those bolts. I worked on Sparrow's car and I remember recalling how this job is absolutely impossible without doing so. On a funny note, instead of using a big extension to get to the 2 top bolts, I used a 17mm wrench from the top of the engine bay to knock them loose, lol...
Old Apr 23, 2010 | 01:23 PM
crank's Avatar
i have seen members do it without dropping the subframe tho, i have no lift and dnt feel like droppin the subframe. it is possible from the top right ?
Old Apr 23, 2010 | 02:21 PM
sparrow's Avatar
You don't have to literally drop the subframe. You just lower it a few inches by loosening the bolts.
Old Apr 23, 2010 | 02:30 PM
crank's Avatar
hah thanks, hope that wont put to much stress on the subframe bolts though.
Old Apr 23, 2010 | 02:31 PM
Voodoo_S2K's Avatar
. If you have an impact gun, it takes like a few seconds per bolts. There are 6 bolts you need to loosen. You also need to disconnect the steering wheel shaft from the rack.
