Insulating stock airbox and intake hose with Thermatec heat wrap...
Did you run the insulation all the way under the airbox? On mine, instead of going the "radmat" route, I covered the front/underside of the airbox. I haven't taken any measurements but essentially all that is not covered/insulated is the horn and the top of the airbox.
Thanks to you and everyone else over the past year or two that came up with this.
Thermotec is available at http://www.jegs.com and http://www.summitracing.com
I bought the silvery bubble-wrap stuff from Home Depot, it's apparently used as additional insulation in attics (just wide enough to be nailed up to the joists/studs).
[QUOTE]Originally posted by marcucci
[B]Did you run the insulation all the way under the airbox? On mine, instead of going the "radmat" route, I covered the front/underside of the airbox. I haven't taken any measurements but essentially all that is not covered/insulated is the horn and the top of the airbox.
