ITB's
Old Feb 5, 2006 | 12:58 PM
A769's Avatar
Default ITB's
hey everybody, im not sure if this is supposed to be in here or not but i was just wondering what all would i need to run individual throttle bodies? i was looking at the toda itb's but wasnt sure if there was any other company making them. if yall could help i would appreciate it. thanx
Old Feb 5, 2006 | 04:00 PM
milkbubble's Avatar
Alot of money, AEM EMS, Alot of Tuning.. im sure im missing alot..
Old Feb 5, 2006 | 04:51 PM
umop-apisdn's Avatar
Nope, you pretty much summed it up into one tidy sentence.
Old Feb 5, 2006 | 07:16 PM
BigpoppaHurtm's Avatar
TWM makes itb's for the s2k as well. http://www.twminduction.com/ThrottleBody/T...tleBody-FR.html
While your at it you may want that hondata intake manifold heatsheild. People disagree as to whether or not it makes power, but I personally believe that a lowered intake temp=more power. You may also want to check out this or last months issue of honda tuning which features a S with TWM itbs. Good luck.
Old Feb 5, 2006 | 07:23 PM
XclusiveAutosports's Avatar
Yes, you will need an EMS and a good tuner, but I have read on here that they are a real pain to tune for a street car.
Old Feb 5, 2006 | 07:50 PM
ADA///M's Avatar
it shouldnt be that hard......i cant see why someone hasnt figure out a piggy back system for the stock ecu to use with ITB's yet....
my old 88 m3 has ITB's stiock and its pretty simple....the ecu is very basic too
Old Feb 6, 2006 | 05:34 AM
vtec9's Avatar
Originally Posted by milkbubble,Feb 5 2006, 08:00 PM
Alot of money
haha thats exactly what I as going to type
Old Feb 6, 2006 | 11:49 AM
Cyclon36's Avatar
Hayward performance makes an ITB setup for our cars as well. Kingmotorsports.com use to sell them. I don't know if they still do. There are a few guys on here that had an ITB setup you should probably contact. Learnerspermit is one of them. I think after all is said and done with, you end up spending more for ITB's than you do for a supercharger or turbo.
Old Feb 6, 2006 | 12:59 PM
Race Miata's Avatar
ITB has a quite non-linear (and even non-1-to-1) relationship between MAP sensor signal and air flow. While this behavior doesn't affect full-throttle fuel/ignition tuning much, part-throttle accuracy can be very tricky for tuning ITB. When I had ITB with my miata, the SDS fully programmable standalone ECU (not a high-end one) had no problem with full-throttle tuning and was OK for part-throttle tuning and passed emission tests no problem (which is NOT a given for ITB tuning) with cams, port work, etc. It's only after my TPS-blending add-on circuit that I could really have good margins in the tuning with the ECU. I doubt a piggyback can do a good job in that regard because of the unique MAP sensor signal to air flow characteristics.
IIRC, E30 M3 runs MAF instead of MAP. MAF doesn't have to deal with the unique MAP-to-air-flow characteristics from using MAP sensor and therefore requires a less sophisticated ECU. But then, the problem with using MAF for ITB is that MAF is located further upstream of the throttles plates. This will 1) delay response of air flow signal, 2) require a limited-size airbox/plenum between ITB and MAF that reduces instant throttle response from the ITB.
Old Feb 6, 2006 | 02:02 PM
Birdie's Avatar
If you can find a right tunner that know ITB's. Let me say you will have one heck of a respond machine.
AWWHITE s2k
Jul 1, 2012 06:05 PM
conboracing
Dec 9, 2011 06:59 PM
s2k_Zyke
Apr 20, 2011 10:17 PM
AIm2kil
Mar 27, 2010 02:22 PM
NVD52K
Apr 20, 2009 05:36 AM
