J's racing f22C
Old Mar 15, 2005 | 06:51 PM
  #251
ultimate lurker's Avatar
No, because the change that makes the CTAE manifold produce power lower in the rpm range is a longer runner, which has a lower resonant frequency.
UL
Old Mar 15, 2005 | 08:34 PM
  #252
CynCrvrAP1's Avatar
hey ul,
when doing a set up, such as the one you posted. is the aem gonna make more power than a mugen intake? is there really that much power to be gained through a v2 when compared?(i ask you this cause you see it alot im sure)
i plan on sending my head to joe soon after i get my j's header exh, then have you tune the ems. jus a little curious. thanks
marcus
Old Mar 16, 2005 | 07:07 AM
  #253
I've never dyno'd the Mugen back to back with another intake, so its hard to say. The Mugen does seem to work, we just don't know how well since its so rare (I've dyno'd one I believe).
UL
Old Mar 16, 2005 | 07:40 AM
  #254
VeilsideAP1's Avatar
Originally Posted by CynCrvrAP1,Mar 14 2005, 06:38 PM
his shop is in torrence california.
good luck
thanks for the info, as soon as I have all the parts together I'll probably head out there for a couple weeks... worse places to be than cali...
Old Mar 16, 2005 | 09:47 AM
  #255
CynCrvrAP1's Avatar
UL
ILL BE NUMBER TWO
NO PROBLEM VEILSIDE, LET ME KNOW WHEN YOU COME OUT
Old Apr 22, 2005 | 03:29 AM
  #256
AusS2000's Avatar
Originally Posted by terd ferguson,Mar 5 2005, 06:43 AM
Yes.
Are we still waiting or have you conceded defeat?
Old May 4, 2005 | 07:59 AM
  #257
S2kRob's Avatar
UL,
How does this sound for an F20C buildup?
Stock 2.2l crank.
Upgraded conrods.
Upgraded pistons.
Alaniz headwork, intake manifold porting, big bore T-body.
J's/Toda/Mugen or some other design headers.
Test pipe
J's/Mugen intake
Free flowing exhaust
AEM ECU
Toda cam gears.
Would this make a good street/track day engine? Something with good torque and power, excellent throttle response, and maintain the 9k rpm redline?
I'm thinking of a NA motor project this coming winter . . .
Thanks Shawn.
Old May 4, 2005 | 06:14 PM
  #258
Sounds about like what I want to do on my car, except I'm going to sleeve it out to about 2.3 liters (and probably still run a cat). Just got a line on a cheap used block today as a matter of fact...
UL
Old May 4, 2005 | 07:39 PM
  #259
S2kRob's Avatar
If you sleeve it out, will you still be able to keep the 9k redline?
And yeah, I will probably keep the cat as well. Is a higher flow cat worthwhile?
Old May 5, 2005 | 01:11 AM
  #260
DesertRat's Avatar
Originally Posted by S2kRob,May 4 2005, 07:59 PM
UL,
Stock 2.2l crank.
Upgraded conrods.
Upgraded pistons.
Test pipe
J's/Mugen intake
AEM ECU
Toda cam gears.
Thanks Shawn.
Very nice setup S2kRob!
May I ask what TB size are you planning? 70mm / 74mm?
