J's racing f22C
Old May 5, 2005 | 07:42 AM
  #261
ultimate lurker's Avatar
Sure, bore doesn't noticeably affect redline (at least in these circumstances).
I would like to find a 3" diameter cat if possible.
UL
Old May 5, 2005 | 07:48 AM
  #262
S2000_Europe's Avatar
does anyone knows the formula to calculate the rod ratio, I want to know which is the limit of my engine.
redline is also affected by the weight of the componentes, how much weight the stock piston
THX
Old May 5, 2005 | 09:27 AM
  #263
sund's Avatar
After following this thread a bit, I want to build a reliable motor. Have all the issues with the AEM EMS been resolved i.e. temperature gauge, idle, startup, especially on an 04+? Is the only way to achieve any good power is by using the EMS? I'm up north in WA, and don't know of any good EMS tuners. On previous experience, full engine management systems didn't run 100% reliable.
Are the changes mostly to the fuel curves, or are there a lot of timing changes?
Old May 5, 2005 | 08:15 PM
  #264
BroInTheKnow's Avatar
Banned
i would guess the motor is easily 10g's
Old May 5, 2005 | 08:16 PM
  #265
Banned
Originally Posted by DesertRat,May 5 2005, 01:11 AM
Very nice setup S2kRob!
May I ask what TB size are you planning? 70mm / 74mm?
74 of course. he's got upgraded pistons and i'm sure he increased the compression.
Old May 5, 2005 | 10:41 PM
  #266
AusS2000's Avatar
Maybe you should try reading the thread.
Old May 6, 2005 | 06:33 AM
  #267
Banned
I have more of a life than reading 11 pages.
Old May 6, 2005 | 07:53 AM
  #268
Sund,
The current state of the AEM EMS is quite good. The new 1052 box in particular, running V1.11 software, is a great fit on the S2000. It starts and idles very well. The temp gauge issue is still unresolved, but we usually just set the the check engine light to turn on if coolant goes above 230 F.
While I'd love to tune your car for you, I'm in SoCal. But you are fortunate to have good tuners in your area. Give a call to Torquefreaks/Horsepowerfreaks. I believe they are in Oregon and have tuned a number of S2000s with EMS.
UL
Old May 6, 2005 | 09:04 AM
  #269
RyanS2000's Avatar
THX
Well the formula for rod ratio is simply:
rod length/stroke = rod ratio
...but if you're trying to figure out the limits of your engine you probably want to calculate piston speed which I don't know the formulas for off the top of my head.
Old May 6, 2005 | 10:27 AM
  #270
CrazyPhuD's Avatar
Originally Posted by ultimate lurker,May 6 2005, 08:53 AM
Sund,
UL
actually modifry's got a great fix for the Temp gauge issue.....
https://www.s2ki.com/forums/index.php?showtopic=232488
Great work and by the time I'll be interested the MY04+ version should be out...
