knocking at idle
That's way louder than a timing chain tensioner usually is.
Start unplugging coil packs 1 at a time. If the noise is reduced, you've gout either a damaged rod bearing, or a scuffed bore on whatever cylinder the noise changes on.
Sounds like a scuffed bore to me.
Have you checked the oil level?
does not sound good. FI and running lean and highway pulls do not mix well. Im guessing its in the block , any un usual smoking maybe cracked piston. maybe rod bearing . hope im wrong . good luck deff get a scope on that block to listen, a long handel screwdriver will work put the head on the spot you want to hear and the handel on your ear it works great
nope, the noise didnt go away when i took out individual plugs... it only gave me a check engine light... how do i reset the ecu without having to undo the battery or disconnect the wiring harness?
the engine oil is in the middle between H and L...
When i took the plugs out the engine started to run bad and the noise got a bit slower... but never went away...
When i put a wrench to my ear i heard it most prominently on the intake manifold...
[QUOTE=SILAP1,Dec 12 2006, 07:08 PM] does not sound good. FI and running lean and highway pulls do not mix well. Im guessing its in the block , any un usual smoking maybe cracked piston. maybe rod bearing . hope im wrong . good luck
Originally Posted by Soul Coughing,Dec 12 2006, 04:43 PM
no odd smoke, i am running it around 13-12 with the FPR turned up a bit... THe car has lost no power
Also, I took this video last night, and tonight the knocking noise isnt as loud
Got a stethascope? They have them at sears for about 20 bucks.. or you can use a looong screw driver and put your ear to the handle while touching various parts of the engine with the tip. Its a good way to locate noises etc.
