knocking at idle
Old Jan 12, 2007 | 08:07 AM
  #31
fperra's Avatar
If it was me, rather than buying a new block I'd have the block sleeved and put in new CP piston. If you are not planning to up the boost too much, you could go with 10:1 compression ratio. I'm guessing here, but you could probably do the block and pistons for about $2000 if you use the stock rods. New bearings and retainers would be in order also.
Old Feb 2, 2007 | 09:32 PM
  #32
RACER's Avatar
update?
Old Feb 3, 2007 | 12:31 AM
  #33
AP1 S2K's Avatar
that really sounds like a spun rod bearing
Old Feb 3, 2007 | 01:31 AM
  #34
RACER's Avatar
it's a rocking nod.
Old Feb 3, 2007 | 07:07 AM
  #35
TitusS2k's Avatar
i saw above you turned the nut on the FPR a few times before you went and ran the dog shit out of your car?
Thats not too smart, All you did was you overloaded the engine way to many time. WIth FI you can be supre repetitive, over and over. Looks like you learned your lesson!
Old Feb 3, 2007 | 10:05 AM
  #36
RACER's Avatar
Spun bearings dun't go "knock, knock, knock". When a bearing spins, the crankshaft no longer spins
Old Jan 29, 2008 | 06:57 AM
  #37
Soul Coughing's Avatar
update to everyone that read this!
It was a scuffed bore, surprisingly, not just on cylinder #4!
Old Jan 29, 2008 | 11:16 AM
  #38
s2000 gib's Avatar
so what did you have done to it then?
new pistons? sleeves? new rods?
Old Jan 29, 2008 | 02:36 PM
  #39
[QUOTE=s2000 gib,Jan 29 2008, 03:16 PM] so what did you have done to it then?
new pistons?
S2KnIt
Aug 28, 2013 08:01 AM
Yamba6
May 10, 2011 04:36 PM
Kompressor
Feb 7, 2008 06:38 AM
B.C.
Dec 29, 2005 12:27 PM
demonderrick
Feb 19, 2004 11:57 AM
