Knocking sound
Old Feb 26, 2012 | 10:01 AM
Griff816's Avatar
Default Knocking sound
Last week my car developed a knocking noise and it sounded like a scored cylinder. I didn't take a video of it but it sounded similar to this:
http://www.youtube.com/watch?v=rWObWwby4M8
Thinking #4 was the problem, I unplugged the injector for it and the sound went away. I swapped the plugs and coil packs around to see if they were the problem but #4 still sounded bad. After that I did a compression test and came out at ~220 across all cylinders and inspected the bores of all the cylinders from the top with a borescope and from the bottom after dropping the pan just to make sure they weren't scored. I took the end caps off the con rods and the bearings and journals were fine. There were no metallic flakes or anything shiny in the oil or the filter. I also took the valve cover off to see if there was anything broken in the valvetrain but everything looked normal. At this point I don't know what else could be causing the knocking sound. Anybody have an idea of what it could be? Its a MY00 w/ ~68k on it.
Old Feb 26, 2012 | 10:38 AM
NFRAP2's Avatar
I know you said you checked the bearings... but that sure sounds like rod knock in the video you linked.
Old Feb 26, 2012 | 11:04 AM
meccjoo's Avatar
Old Feb 26, 2012 | 12:53 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
#4 cylinder failure or spun bearing, guaranteed.
RVA_S2K
Feb 18, 2015 09:38 PM
QuangNguyen_89616
Jan 2, 2013 10:47 PM
mirokoon
May 19, 2011 07:28 AM
xman03
Feb 25, 2008 10:59 AM
iispms
Apr 4, 2002 07:01 PM
